wires, air intake upgrade
Old 21 Feb 2009, 02:21 pm
Default wires, air intake upgrade
Hello fellow pt'ers,
I'm looking at upgrading my standard wires, and putting in an air intake system. For wires, I have no idea what to get, so my question is what after market wires are a good investment?
The other thing I'm looking at is an air intake system from K&N, and the one I was looking at was the Typhoon Air Intake, but what is the difference between the Cold Air intake and the Short Ram Intake? Also are there any other companies that make a good intake system? Looking for HP increase and reusable/washable.
http://www.knfilters.com/search/prod...Prod=69-2541TB
Wires and Intake will be for an 03 GT
Thanks in advance for any help, it is much appreciated.
2003 GT 5-speed
Borla dual cat-back exhaust
Stage one
Blow Off Valve
Chrome Grill
Konig 17" rims
Old 21 Feb 2009, 05:36 pm
Default Re: wires, air intake upgrade
The best wires, in my opinion and experience, are Cranes. Only 25 ohms per foot!
www.RaceAndStreet is where I get mine.
There's a lot of opinion on intakes - I just want to point out that cold air is good for HP, but warm air is better for mileage. Mileage drops in winter, the computer makes the mix richer with lower temps.
K&N makes quality stuff.
What you will find that throttle response is quicker.
Old 21 Feb 2009, 06:40 pm
You'll get no noticeable increase in hp or better mpg from an intake. All you are paying a lot of money for is a racier look and a cooler sound. A K&N drop in filter is a lot more cost effective.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 22 Feb 2009, 01:01 pm
Thank you Mean Green and quicksilverdon, I looked at those drop in filters, and will make a discision in a little bit after some more research. Thank you for your help, like always it is much appreciated =)
This is MY first car, so I'm kinda new to all this >.< before my dad did all the work needed on the Blazer so I didn't really pay attention...so far though I'm am absolutely loving the PT
2003 GT 5-speed
Stage one
Blow Off Valve
Chrome Grill
Konig 17" rims
Old 22 Feb 2009, 01:45 pm
Especially in a turbo you want to keep the intake air as cool as possible so an enclosed system is best, a true cold air intake system. You really don't need an aftermarket intake until you go big turbo.
Old 22 Feb 2009, 11:17 pm
I just installed a K&N intake this weekend (FIPK), on my 04 Turbo Lite. While I believe what you say, it does seem like the turbo spools faster with the new intake. It could just be my imagination (I dont have a boost gauge to verify) but it feels like the boost is hitting harder, faster, than it did with the standard "box" intake...
Old 23 Feb 2009, 01:58 am
What goes in must go out. While you may have improved the in, if you're still running with the stock turboback exhaust (TBE), you still have restriction. You need to replace the TBE to get better turbo spool. What you are probably hearing now is the surge valve and more intake sound. Sounds racier, but you are now sucking hot engine air, which on the dyno costs both hp and tq. Still, if you're not into squeezing every ounce of hp/tq out of your engine then it does look and sound cool.
Old 23 Feb 2009, 08:01 pm
I have a borla dual catback exhaust, will that help with the "out" part of the system?
2003 GT 5-speed
Stage one
Blow Off Valve
Chrome Grill
Konig 17" rims
Old 24 Feb 2009, 01:00 am
Is it 2 1/2" ? A catback is a good start but there is still restriction in the factory downpipe, cat and 02 housing. If you aren't taking the power levels much further then the catback exhaust is just fine. When you up the boost then upgrading the restrictions would be necessary.
Old 24 Feb 2009, 08:14 pm
I don't know what size it is >.<
However,
Thank you everybody for your input, especially Mean Green, all of you have been alot of help =)
2003 GT 5-speed
Stage one
Blow Off Valve
Chrome Grill
Konig 17" rims
3/25/05 UPDATE - DONE! - New Plugs and Wires NGK BumperBob Tech & Performance Forum 14 31 Mar 2005 01:06 am
Order of Install ? - S1, BOV, Intake, Wires jramosGT Stage Turbo Kits 7 27 Apr 2004 07:54 pm
3" cold air or 2 1/2 " hot air intake ?????? amx1397 General Turbo Discussions 12 25 Jan 2004 12:35 pm
AIR INTAKE FROM AMX1397 amx1397 Turbo Performance 6 03 Jun 2003 10:22 pm
