Turbo Timer How-To Wire Guide (Blitz FATT)
Old 25 Aug 2003, 05:52 pm
Default Turbo Timer How-To Wire Guide (Blitz FATT)
Thought I would post these pics I made For Wiring the Blitz FATT 2 Turbo Timer.
First off, here is the wiring schematic from ther Service manual for the Ignition Harness connector. We need to tap the 1,2,3 wires.
A picture of the Wires that need to be tapped. And the corresponding colors for the Blitz Harness.
A picture of the Blitz harness tapped into the wires.
A picture of the Connector back in place and the Blitz harness zip tied out of the way of anything. Also make sure the wires have enough slack so that the steering column can move up and down.
Connect the 2 grounds and purple wire to a good ground. In this case I used a fuse box screw.
Now all you have to do is figure out where you want to put the control module.
Hope this will help you out!
Enjoy!
-=Matt=-
Old 25 Aug 2003, 06:31 pm
is there a way to save forum post's?
punch
Old 25 Aug 2003, 07:45 pm
Great pictures!!!
Like they say: "One picture is worth more than a thousand words" or something like that.
Ian
Old 25 Aug 2003, 10:59 pm
Send a message via AIM to Mr.Blonde
This is really great. Thank you so much. I think I know what I did wrong, for some reason I thought I had to splice a black wire, I will try this tomorrow and let you know how I make out.
Now with stage 1
Just a GT... Thats tearin\' arse on the driveway.
http://www.cardomain.com/id/themanfrmokinawa
14.626 @ 94.74
stage 0 , intake and exhaust only.
Old 26 Aug 2003, 02:38 am
Send a message via AIM to Exhaust Depot
You do, that way your radio and dome light do not stay powered on.
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
Old 26 Aug 2003, 12:41 pm
Is Chipmunk's splices correct then? I dont see the black wire spliced.
Now with stage 1
14.626 @ 94.74
Old 26 Aug 2003, 12:51 pm
Hmmm, well my dome light does stay on when the timer is running the car, but the radio doesnt. There are (2) accessory wires, number 3 which is red, and number 7 which is Black with a white stripe like hector said. Both wires will work, I think I will try the black with white stripe when i get back on friday. Hopefully it will take care of the dome light.
-=Matt=-
\'03 Yellow SRT-4
Old 26 Aug 2003, 04:32 pm
What is the talk about a black wire splice?? My radio stays on and has since the TT was installed. I thought that was normal. Hector was this a new find after the initial wire harness was made?? Thanks,
Don
2003 PT GT
Old 29 Aug 2003, 05:26 pm
I spent about a half hour today trying to get my TT to work. No luck. The only difference I see with my wire harness and the one pictured is that mine has extentions, attached to the blue with red stripe is a black wire, attached to the green with red stripe is a solid green, and there is a red on the red. I wouldnt think that this would make a difference though. The only thing, that i think could be wrong is where the ground plugs into the TT "brain". is there anything special that you have to do with this or just plug it in? Does anyone have any ideas on how I can get this to work?
Now with stage 1
14.626 @ 94.74
Old 29 Aug 2003, 09:47 pm
Mr. Blonde, The only way to approach this is to use a continuity meter (an Ohm meter). Remove the steerinmg column cover, disconnect the switch plug, and remove the plug in the back of the Timer module. Check for continuity in all wires from the plug that goes into the module to the inside of the plug that goes into the ignition switch. If you have continuity there there is nothing wrong with the wiring. If the wiring checks out then the module is probably at fault and needs to be replaced. If you need or want to discuss this further send me an e-Mail @ gill66482@comcast.net there may yet be a few other things to try. Contact me & maybe we can talk. [|)]
Alan
FS: Blitz Turbo Timer cruizer_style Classifieds: For Sale/Trade 15 03 May 2005 12:41 am
Turbo Timer .... onedivinehammer Turbo Performance 19 08 Aug 2003 05:59 pm
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Blitz Dual Turbo Timer, anyone? magictrickboy71 Turbo Performance 10 01 May 2003 05:10 pm
Turbo Timer Installed Exhaust Depot Turbo Performance 11 13 Apr 2003 12:12 am
