No Codes yet check engine and oil light won't go off
Old 21 Mar 2009, 12:03 am
Question No Codes yet check engine and oil light won't go off
2 hours after I left the lot the check engine light( stayed on) and oil light with the bing sound came on everytime I hit the breaks. I bought it to the dealership and the could not find anything wrong. Two days later the check engine light came on again, no code when I bought it to discount auto, the dealership, and did the key/reset button trick. The gas cap is on tight and my tank is full. What else could it be? (2004 Turbo)
Old 26 Mar 2009, 09:35 am
PT_Cuda's Avatar
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Default Re: No Codes yet check engine and oil light won't go off
oil pressure sensor or the oil sender is bad.. Is my guess when you get an oil light.. Sensor is about $12 bucks, sending unit not sure the cost on that one..
Sensor is a DIY repair, backside of the motor sending unit not sure.
Old 26 Mar 2009, 07:26 pm
Welcome.
Did you just buy the PT?
Has oil light come on again?
Take it back. In most states you can't get it registered with a check engine light on - have them fix it.
