Intake Manifold
Old 28 Mar 2009, 10:15 pm
turbo_pt2003's Avatar
Default Intake Manifold
Does anyone know where i can buy a aftermarket/performance intake manifold for a 2003GT pt cruiser iv'e been looking high and low cant seem to find anything, or mabey a turbo exhaust manifold? all help is appreciated (mean green help me out bro)!!! lol
Old 29 Mar 2009, 12:57 am
Cathy06PT's Avatar
Send a message via AIM to Cathy06PT
Default Re: Intake Manifold
Did you try ebay? I know there are sites out there.
Old 29 Mar 2009, 01:41 am
Go here and ask. PTCrew.com - Learn it or Burn it. Performance parts are getting hard to come by for the PT turbo.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 31 Mar 2009, 06:49 pm
The best performance intake for the 2003 is to upgrade to the composite manifold that comes stock on the '05+ models. It has very smooth runners and has a diverter built into it the resolves a lean condition in the #3(it think) cylinder. You would have to cut open the stock manifold, port it and then weld it back up to get the flow of the composite and you would not get the diverter.
You can't really change the exhaust manifold as the turbo housing is cast into the manifold. If you are udgrading your turbo to a bigger one you might find a custom tubular manifold for it. I think someone built one at one point.
Old 05 Apr 2009, 03:10 am
gschnu's Avatar
Hello,
that sounds interesting! Is there a drawing or picture that shows the difference between the earlier cast alloy intake manifold and the later composite manifold?
I would be really interested especially how that diverter looks!
gschnu
2003 PT Cruiser GT 2.4 t, black w/ silver roof, Hurst equipped
Old 07 Apr 2009, 02:58 pm
nevinsrt's Avatar
EDIT: deleted
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 08 Apr 2009, 10:08 am
gschnu's Avatar
Why did you delete it - I liked the pics in the email notification!
Is the mentioned diverter where I made the red circle?
gschnu
Old 08 Apr 2009, 10:11 am
nevinsrt's Avatar
gschnu
because the pics were of the outside and not of the inside diverter. i read wrong.
Nevin.
Old 08 Apr 2009, 02:29 pm
gschnu's Avatar
Ok, but where is that diverter? Must be something like a "flap"!?
gschnu
Old 13 Apr 2009, 05:23 pm
It is not a flap. It is just molded into the runners. It just evens out the airflow to the cylinders.
"Cool Induction" Intake Manifold Cover & Insulation cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:22 pm
intake manifold??? PTcruzer02 Turbo Performance 5 26 Dec 2008 10:58 pm
Plastic Intake Manifold cracked-boost leak! littleblueGT General Turbo Discussions 1 31 May 2007 03:25 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
