Fog/Touring lights will not turn off
Old 05 Apr 2009, 07:10 pm
PTATER's Avatar
Default Fog/Touring lights will not turn off
It's Sunday, my wife and I got ready to go somewhere, I unlocked the drivers door, then turned the key again to unlock all other doors, but this doesn't work. I open the drivers door, hit the door unlock switch, nothing happens. I put the key in the ignition, turn it and nothing. I then notice no interior lights. I open the hood and put the battery charger on the battery, it is dead (battery is about 3 months old). I let the battery charge for about 3 hours.
I checked the car over after the battery is charged for anything left on,and notice the fog/touring lights on. I had my wife shut them off (switch was in off position) she fumbled around with the multifunction switch and they only go off if the headlights are on, she shut the headlights off and the fog/touring lights come back on. We can not get them to go off, this is with the key OUT of the ignition. I disconnected the positive terminal on the battery thinking I could reboot the system, this didn't seem to work.
Any ideas other then disconnecting the fog lights, they are draining the battery.
Thanks.
Rick
P.S. 2003 PT GT Turbo, Idaho USA under 75,000 miles
Old 05 Apr 2009, 07:37 pm
Default Re: Fog/Touring lights will not turn off
Hey PTater, sorry that your first posting has to be asking for help. I believe that you will have to get a new Multi Function Switch, that is the component that is the whole stalk. You will have to take the housing off of the steering assy, making sure that you remove the old blinker "box" and put it in the new MF switch. It is NOT a hard job to replace it, but you have to get the correct switch for the fog/touring lamps. The dealer is the best place to get it and will run about $75-80.00.
Old 06 Apr 2009, 01:45 am
PTATER's Avatar
Hooligan, Thinks for the info. I ran a couple of tests and nothing worked. I could get the lights to shut off a couple of times by turning on the switch and then smacking it off. this only worked a couple of times and not all the time, so I determined that the multifunction switch must be bad. Thanks for your clarifying my thoughts, and letting me know that not just any switch will work. I thought it was rather simple to replace as I looked around the column, just to see if it would be easy or not. Doesn't appear to take any special tools.
Rick
Old 06 Apr 2009, 07:23 am
The switch itself is held in with Torqx screws
The housing around the steering column has 2 phillips screws you get at from the bottom, then it snaps apart.
Old 02 May 2009, 12:11 am
PTATER's Avatar
Hooligan and Quicksilverdon, I want to thank you 2 for your help. 6 screws, 3 differant styles. And 2 and ahalf hours later the new multifuction switch is inplace. Not a hard task at all. My excess time was spent looking for the right torx head, bit and a lost screw. Now my next task is to add about 20 ground cables to stop the annoying light flickering.
Thanks again
Rick
Fog lights won't turn off DCruzer Tech & Performance Forum 22 12 Jul 2018 07:29 am
Fog lights won't turn on coolvirus General PT Cruiser Discussions 33 17 Sep 2017 12:50 pm
Fog lights won't turn off... emhymas Tech & Performance Forum 27 20 Nov 2016 08:57 pm
2006 Touring Edition - Lower lights never turn off EmeraldICE General PT Cruiser Discussions 7 12 Apr 2008 08:59 pm
Red Rear Turn lights Crash Exterior Accessories Forum 7 11 Oct 2001 04:28 am
