mid to high rpm miss in boost
Old 21 Apr 2009, 01:29 pm
Default mid to high rpm miss in boost
I'm getting a real hard misfire around 4-5k rpms's in all gears. I have 3"exhaust, 3" intake, kn filter, mopar plate, and no boost controller (stock wga). According to my gauge, i'm spiking about 15psi and holding 12-13. whenever it hits about 14psi or so it misfires hard. I have non stock wires (whatever came on the car, not stock though) and new stock copper plugs gapped at .032. anything that i could be missing? I'm very familiar with the srt platform and have never had this problem.
2003 PT Cruiser GT- 15psi, 3" TTAB pipe, K&N drop-in, 3" downpipe, 3" downpipe back exhaust, tokico blues, boost gauge....breaking loose at 50mph
Old 21 Apr 2009, 02:54 pm
Default Re: mid to high rpm miss in boost
Your plug gap with stock Copper Plus plugs is smaller than my Stage 2 SRT-4 (.035). When I had a modified '03 GT my plugs were gapped at .040 to fix the high rpm misfire I had. Could be your wires, too, especially if you have no idea what kind they are and how long they've been on there.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 21 Apr 2009, 07:49 pm
ChefTank's Avatar
Back the gap out around .038.... check your plug wires (swap them)..... if that doesn't help it's probably the coil (stock? how many miles?)
Josh
Old 22 Apr 2009, 10:23 am
yea my srt a while back was gapped at .038, that's why i thought this was odd. I'm guessing it is the wires. I'm going to order some new ones here soon and see how it does.
Old 22 Apr 2009, 08:28 pm
My guess would be wires - but throw new plugs in at the same time. Then, play with the gap. I've read of some who swear by gap as low as 0.028, but I'd say experiment.
The stock coil is nearly never at fault.
Old 23 Apr 2009, 05:33 pm
You don't mention if you check for codes or not.
Old 26 Apr 2009, 09:12 pm
no codes present. Im guessing wires. the plugs i have in there now have about 500 miles on them. What would be the best set to go with? I was thinking magnecore because of the low resistance per foot of wire (25 ohms/ft i believe?)
Old 28 Apr 2009, 07:46 am
The 25 ohms/ft was Crane wires - don't know if you can still get Cranes - but many swear by magnecore (and many swear at stock wires)...
Old 28 Apr 2009, 06:33 pm
I had magnecore blue wires on there. pulled them off and it said megnecore on it. i got some aftermarket 8.5mm wires from advance. got them for 35 (a friend works there). Cleared up my problem and I'm getting a little better mpg. Plugs i gapped back to .040 and put my spring back on the wga. spiking 15psi and holding 12-13 at redline. No problems whatsoever. Thanks guys.
Old 29 Apr 2009, 06:38 am
Glad you got it fixed
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
high rpm miss 1quickpt Turbo Performance 24 17 Mar 2007 06:54 pm
idle miss and boost surge mtnbktrek General Turbo Discussions 7 02 Feb 2007 04:08 pm
High RPM miss Lee01 Turbo Performance 23 30 Jun 2003 08:25 pm
High RPM Miss potential Fix Exhaust Depot Turbo Performance 11 15 May 2003 06:31 pm
