Thanks fellas. I just heated it up and twisted it off to the side so it wont hit the fuel rail.
On another note I was wondering about the turbo ECU. My customer swapped his stock ECU for an '06 Turbo ECU. Its running kinda rough and I'm guessing its because of the slight differences in the motors. Does the turbo come with a different MAF sensor? I'm thinking that is one of the reasons for rough idle in addition to timing. Thanks for the help in advance. |
From PT Do-It-Yourself.net:
The PT is a speed density design. There is no MAF. It uses MAP manifold absolute pressure and IAT air intake temp sensors. No matter what you add, the PCM will keep the fuel trim at 14.7:1, or stoichiometry. It doesn't say anything about the Turbo model being different than the Non-turbo.
No MAF. The turbo and na are the same. Chrysler makes changes every year and using a different year pcm is not recommended.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
Stock plugs and wires are usually the cause or rough idle, these cars don't idle that smooth when its new plugs and wires, always a little shake to them Just FYI there. Stronger torque struts add to the shake-always feel like the A/C is on.
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though ![]() My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life. |
Thanks guys. His turbo is pretty big and it had a lot of shaft play. I tried to get him to use another one but he wanted to stay with what he had. It smokes pretty bad so I think he's going to listen to me now.
Not to mention its not making any boost. I asked about the MAF because it wont go over 2500-3000 rpm. Any other car that I've worked on with that issue turned out to be the MAF or a vaccum hose. We changed the plugs but he doesnt want to spend the money on the wires. Its getting an error code for TDC, among others, so I'm guessing the timing is off also. |
Ok he's being a "Radio Edit"..
Rebuild kit at least for the turbo, if one is made since you say he's running a big turbo. And wires are a MUST if they are stock ones = crap. Car sounds like its in "LIMP MODE" meaning you can't get it out of second so the car can't eat itself more than it has. You know what its not the car that has an issue, its pulling timing since its overboosting.. I just went back and did some reading, what are you boosting before it went boom so to speak? Stock Turbo PCM? Nope not gonna cut it, you need to have a piggyback to control boost seperately from the PCM since the PCM will NOT allow anything over the basis stock setting and will just try anything to keep it that way..
| Turbo Replacement Question | PTCruzzn | General Turbo Discussions | 7 | 06 Jul 2009 07:14 pm |
| Turbo Brake System Question | R_I_PT | Turbo Wheels/Suspension/Handling | 5 | 03 Nov 2007 07:44 am |
| Turbo manifold question | proxeyed | Tech & Performance Forum | 6 | 29 Jan 2005 12:55 am |
| Turbo Timer Install Question | gsharrock | Turbo Performance | 11 | 02 Jun 2003 07:35 am |
| Hahn Turbo Install Question | PuterTater Cruiser | Tech & Performance Forum | 1 | 02 Oct 2002 09:26 pm |
