Code p0340
Old 16 May 2009, 12:01 pm
Default Code p0340 / Timing Belt
Well guys reading through the forum on this error, it seemed I either had a bad Camshaft Position Sensor or a broken timing belt, well I have just taken the cover off the camshaft sprockets and see no belt.
I have read through the forum and I think that the timing belt is too big of a job for me, I am from the UK just moved to the US, Tulsa, Broken Arrow to be precise, so I really dont know of any decent garages that could do this job at at the propper going rate, so anyone on this forum from Broken Arrow that could point me in the direction of a garage that aint going to rip me off, or any home mechanics that could do this for me at a decent rate, i`m available for helping with labour.
T.I.A...
Old 16 May 2009, 12:29 pm
Default Re: Code p0340
Tommy,
Welcome to the forum. Thanks for reading threw the old postings first and gathering info before your questions. Yes, your right in thinking that the timing belt is not for a novice or even a back-yard mechanic to try and do. There's lots of things that people have run into while changing the belt and a lot of them have had to do it over again. If nobody replies from your area, the first thing to do is get an estimate from your closest Chrysler dealer than you know what to expect.
If there are any car clubs or cruise-ins in the area you might want to talk to those owners for recommendations for a good/hopefully honest mechanic in the area and then talk to him first to see if he's tackled the timing belt and knows what to expect.
We also tell everyone to replace the water pump, tensioner, serpentine and alternator belts at the same time as they are wearable items that are probably in need of changing anyway and especially the water pump as it takes the same number of hours to change that as it does the timing belt. Might as well do both at the same time.
Old 16 May 2009, 01:31 pm
Soonercruiser is from OKC, maybe he can give Tommy some help, not sure the location of Broken Arrow to OKC. He belongs to a couple of PT clubs out there.
Frank where are you???
Old 16 May 2009, 01:51 pm
Default Re: Code p0340 Broken Timing Belt
Thanks for the warm welcome guys, hope Frank can be of some help..
P0340 cam sensor code in 2006 cruiser deighter Tech & Performance Forum 13 12 Jan 2012 07:41 am
2004 PT GT Stalls with P0340 code ron2004gt General Turbo Discussions 18 17 Apr 2011 06:46 pm
Code 2094 Camshaft Position Actuator bank 2 low PTGUY_PSL Tech & Performance Forum 0 27 Dec 2008 08:46 pm
code p0340 sflamedic General PT Cruiser Discussions 5 21 Oct 2008 06:12 am
Dark Plum paint code ChaosTheory The Detail Shop 3 18 Mar 2008 11:03 pm
