PT Cruiser Forum Car Videos
Car Rims
what problems have you had??
  #21 (permalink)
Old 02 Oct 2003, 05:37 pm
LAF LAF is offline
Back from the "stealer". They replaced frozen window motor in drivers door. Check valve for rear washer on backorder. Took my free oil change today 1500 miles, will run this for 1500 more and go synth. Took all my chrome wheels in today. Got pissed the Service manager said he could not do anything until he talks to the rep. Hell all four wheels are pitted and flakeing all along the entire inside chrome. He started a song and dance about warrenty being the face only. I told him bull****, it is chrome platted, it is pulling off and is not right! He said he could not send them back without the Rep oking it as he felt Chrysler would reject the claim. This is total horse ****. Chrome is chrome, pitted and flakeing chrome, is pitted and flakeing chrome.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT- 30,000 Miles on the clock
Stage 1, Mopar BOV, Brand X Air Box Pipe, K&N drop in, White silencer removed, Black lower silencer cut, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axel back exhaust, Rear Spoiler.
Greddy Profec II B, Turbo Chargers Wastegate set to 13# Russel Brake Lines Hawk Brake Pads Power Slot Cyro Rotors
Bag Stage II :-p
  #22 (permalink)
Old 02 Oct 2003, 06:35 pm
OurPTGT OurPTGT is offline
Read for yourself
http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=4026
  #23 (permalink)
Old 03 Oct 2003, 04:07 am
Pipes Pipes is offline
Hi all... I have a drivers seat that is squeeky and the back rest feels loose. Also, I also have two if not more wheels that are pitting or bubbling . The dealership knows about these issues and they say they will look after them . Other than that.......it's full steam ahead !!!
  #24 (permalink)
Old 03 Oct 2003, 09:29 am
DTs_PTGT DTs_PTGT is offline
LAF,
I had all 4 rims replaced under warranty, no questions asked. My car was maybe 3 months old at the time. If that dealer won't take care of you I'm sure another one will.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
  #25 (permalink)
Old 06 Oct 2003, 06:07 pm
ote69 ote69 is offline
slave unit went out....5-speed gt
  #26 (permalink)
Old 07 Oct 2003, 09:42 am
TripleJackInGA TripleJackInGA is offline
I just dropped mycar at the dealer for it's first visit.I have done the oil changes myself, but had been saving up some warranty work.
I reported the following when I dropped it off:
-Power Steering whistle(I was told yesterday that the part,I'm assuming a rack & pinion unit, is on National backorder)-10/8 update: I am told this is on backorder and they do not have an ETA
-High-RPM miss - 10/8 update: Told that the PCM is on backorder with no ETA
-Very small amount of trans. fluid on the bottom-center bolt on the diff. cover.(I was told yesterday that this was from a leaking axle-seal and was replaced)
-Coolant leak on the back side of the engine (I was told yesterday that as I suspected,one of the cheap-o crimp-type clamps on one of the small coolant lines was not tight enough.It was replaced with a traditional-style clamp.)
-SIRIUS radio loses signal on hot sunny days. (I doubt they will get this one fixed,especially since the weather has cooled off and they likely cannot reproduce it.)
I do not forsee any problems getting any of this fixed.It's all either simple minor stuff, or things that have been well documented by others and/or has an existing TSB.
I'm driving the Shelby Dakota while it sits at the dealer.I told them to keep it until it's all done.I hate dropping a car off and then picking it up a couple of days later with them saying I have to bring it back for some reason.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
  #27 (permalink)
Old 08 Oct 2003, 10:39 pm
onedivinehammer onedivinehammer is offline
What exactly happens with the "high RPM miss?" How do you know if it's happening?
PS - My only issue has been a non-functioning rear wiper. Soon I'll take it back to the dealer; just haven't had the time.
\'03 5-spd GT Turbo
Stage 1
AiRaid Intake System
Eibach Pro Kit Springs
Eibach Anti-Sway Kit
BTG Turbo Strut Bar
Ceramic brake pads
Mopar/Borla Dualies 2.5\"
Oh ... it\'s Onyx Green
  #28 (permalink)
Old 09 Oct 2003, 02:33 pm
JD-GT JD-GT is offline
I took mine in for the following:
- Drivers side window was making a squeaking or binding noise
(Replaced Window Regulator)
- Oil light came on and chimed.
(Replaced Oil Pressure Sensor)
- Engine overheated
(Flashed Stock PCM)
- Steering wheel vibration
(Corrected Tire Air Pressure)
Was told to watch my tire pressure very closely with the stock
GT wheels. Mine dropped down to 15psi with-in a couple of weeks due to the temperature changes.
All fixed free of charge of course.[^]
2003 Patriot Blue GT, Stage 1, Screain Demon Coil, Magnecor KV85
  #29 (permalink)
Old 17 Oct 2004, 11:41 am
ptcruiser_58 ptcruiser_58 is offline
I also have a problem with the sun roof. Have had it in the dealers at least five times since the begining of summer for this problem. They cleaned the track and said it was fine...NOT! Well in Sept. someone finally said it was the motor. One was ordered or so they said. It just so happens there isn't a sun roof motor in the whole country. They said the chip needed to be re programmed. The dealer had my car all day this past Friday. I checked it when I picked it up and It still did not work. Now the tech said there is a procedure they have to follow before they change out the motor. I asked why they did not do this in the first place and they did not have a answer. My husband told the manager they will give us a rental the next time I have to take it in to fix this on going problem.Because of this rotten customer service they lost a truck sale. We went to GMC and bought a new truck and I let them know this. Oh yeah they said it was my hand loition caused the steering wheel to wrinkle and bubble. It only took three months before they replaced it.They don't have a problem taking your money but once a manufacture problem arises forget it they don't want to deal with you.
  #30 (permalink)
Old 17 Oct 2004, 12:26 pm
Gary04GT Gary04GT is offline
The problem I had with the turbo engine in my 2003 GT is detailed in the following thread: http://www.ptcruiserlinks.com/forum/...eng ine,noise
I have not experienced any problems whatsoever to date (over 11K miles) on my 2004 GT.
vB code is On
So much problems before inspection Ctown General PT Cruiser Discussions 3 12 Apr 2005 07:45 pm
Headliner Problems!!! ptgtjoe General PT Cruiser Discussions 9 08 Mar 2005 02:46 pm
Window Problems in cold weather franski PT Cruiser Convertible Forum 0 26 Nov 2004 08:19 pm
Any problems from "Lighting up the tires"? crazie.eddie Tech & Performance Forum 6 19 Oct 2004 06:43 pm
Problems Oddcouple General PT Cruiser Discussions 1 17 Nov 2002 01:58 pm
  Credit Cards | Northern Rock | Secured Loan | Loans | MySpace Layouts
