hello all, well most know what i went thru!! what if any problems have you had??
The belt The Tensioner The Pulleys Align the accessories. Maybe I ought to tell him to follow the procedures in the fricking service manual macster macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
day of pick up code p0455 (if i remeber correct) it was small leak in evap blah blah......
The stutter at high RPM. My new MCU is in... unfortunately the new cable they need has yet to show.
Macster, I was getting a slight sssssssk, ssssssk sound the last time it got cold. Is that what you were getting? Overall though, quite happy with my car. Don
\'03 Inferno Red 5 spd. Hurst shifter,Loaded |
Don
Thats it. It "appears" that there is a corellation between washing the car (spraying water on the grill area and around the hood with a water hose and the squeak) What appears to being happening is that the water carries contaminits (sp) on to the pulleys, which causes the belt to slip and hench squeek. The fix is to jack the car up on the passenger side, remove the inner splash panel and the belt. Then clean the pulley's very throughly. Like magic the squeak/ squeal goes away. Donot spray, belt cleaner (wanna buy a can) or any of that crap on the belts. Just clean the pulleys with a good cleaner (I used spray can brake parts cleaner) and it worked for me. I also used a tooth brush which I saturated with the cleaner and put it on the pulleys while the car was running at idle (never claimed to be smart). But I cleaned everything very throughly. I cleaned the "new" belt with a clean dry rag, nothing else. Tthrift also had a similar problem and used a similar solution. But I hope no one is dumb enough to do it while the car was running like I was. Its a skill that I developed, from years of being around rotating machinery, but its still a, extremely, stuipd thing to do. I also brought two stiff plastic brushes from Home Depot to use since they are none abrasive. Sorry for the long post, I'm tired and I'll correct any spelling and grammar errors later. But I just wanted to let you know what I did. I'm very happy with my car, but I want my dealer to follow the procedures in the service manual, when there is a problem. Peace macster
Had a Camshaft sensor go out at about 9,000. It made the engine look like it was running on 3 cylinders. Dealer found it an replaced it in 2 days.
Now I have 11,000 and so far so good.
03 Black GT. Zenon Crusher kit, K&N FIPK kit, MSD coil, crane wires. Daily driver-70,000, Composite intake. My other car is an 8 second vega wagon |
I had all 4 rims replaced due to the chrome bubbling. Also had the PCM replaced due to the 5,200 RPM misfire issue.
Other than that, this thing runs great!
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300. |
I'm taking mine in this week for the following;
High RPM miss 1 Rim, chrome bubbling 1 Rim, pitting Steering wheel "rub" noise Break peddle "rub" noise A "squeaking" sound when I shut the car off
![]() \'03 Black Turbo, Autostick, Removed Intake Silencers, K&N Drop in Filter, MOPAR BOV, Eibach Springs, Kenwood CD/MP3 Player & amp, 12 inch Sub...soon to be a member of the Stage I club... |
Well today had to make a run. Went to put my window down, wont go. Worked an hour earlier on the way to work. Try all others and they work. Not to cool. Icalled dealer and will be there in the morning. First thought was shoot, just put S1 in, and thought I blew something. But with the other 3 windows working, think must just be that button itself.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge. Elbert Hubbard (1856 - 1915) 2003 Electric Blue GT-30,000 Miles on the clock Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners Support Your Right to Arm Bears
| So much problems before inspection | Ctown | General PT Cruiser Discussions | 3 | 12 Apr 2005 07:45 pm |
| Headliner Problems!!! | ptgtjoe | General PT Cruiser Discussions | 9 | 08 Mar 2005 02:46 pm |
| Window Problems in cold weather | franski | PT Cruiser Convertible Forum | 0 | 26 Nov 2004 08:19 pm |
| Any problems from "Lighting up the tires"? | crazie.eddie | Tech & Performance Forum | 6 | 19 Oct 2004 06:43 pm |
| Problems | Oddcouple | General PT Cruiser Discussions | 1 | 17 Nov 2002 01:58 pm |
