OIL FILTER SANDWICH
Old 26 Jul 2009, 06:20 pm
Default OIL FILTER SANDWICH
There is an oil filter sandwich plate that is made to fit between the oil filter and the filter mount. They usually have three threaded oil galley holes. This makes installing oil sending units an easy job. On the Turbo models there is an oil cooler between the oil filter and the mount.
I have installed an “A” pillar three instrument pod. The oil pressure gauge is electronic. I tried to install a “T” fitting to adapt the original oil filter sending unit with the new sending unit. It places the sending units next to too much heat. An easy solution would be to install a sandwich plate, and put the new sending unit in one of the three available oil galley holes. The question is: I have a Turbo with the oil cooler. The oil filter length just barely allows for filter removal. Does anyone know if I can still remove the filter if I install the sandwich adapter?
Another idea. How about splicing a “T” fitting into the oil feed line to the turbo? It is very accessible.
Old 26 Jul 2009, 06:58 pm
Default Re: OIL FILTER SANDWICH
As you noted, there is barely room enough to get the filter out now - adding anything would mean having to tilt the filter even more to get it off.
Why not some copper tubing off the tee fitting by the original sending unit and put the sensor somewhere away from heat?
Old 26 Jul 2009, 10:31 pm
I sent an email to the manufacture of the sandwich. I probably will never hear from them. Thanks for confirming my suspicion about not being able to remove the oil filter. I thought about configuring a new sender mount. It became a plumbers nightmare. There are just too many hot pipes in the area. They even place a heat shield around the present sending unit. The turbo oil line is metal and rubber hose. I will give it a shot this week.
Old 09 Sep 2009, 01:48 am
Apparently the turbos have two threaded ports on the head of the motor, driver side, under the airbox. I've read quite a few threads on this AWESOME forum with this info. This should make it easy to install an oil press or temp sending unit.
'03 GT Black. Looking to upgrade of course!
Old 09 Sep 2009, 03:43 pm
I tried the two ports in the head. I think they are drain galley plugs as they don't carry any oil pressure. The sandwich is out of the question. I ended up taking the filter and oil cool off the mount. There is a 12MM Allan socket deep in the center oil filter mounting threaded bolt. You need a long 12mm Allen wrench. You don't have to remove the oil lines from the cooler. I then removed the mounting bracket from the block. I drilled and taped the mount with a 1/8 27 NPT tap. Drill in a place that wont weaken the bracket. I had to use a 90 degree elbow to allow the sending unit to clear. There is an 'O' ring between the oil cooler and mount. Chrysler does not show the part. It is exactly the size of an oil filter gasket. Hold it place with a dab of rubber cement to keep in place while mounting. A new mount to block gasket was $6.00. Sorry no pictures. It works beautiful.
Old 11 Sep 2009, 01:31 pm
CYCLONE_06's Avatar
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
Why is the sandwhich out of the question ? I have a 2.4 Turbo cruiser, and I installed an oil pressure gauge and sending unit (electronic) with no problem. All I did was went with a shorter oil filter. No big deal.
~CYCLONE_06
"It's been said winning isn't everything... Just not by me."
--Mark Martin
Cabin air filter AlmondTurbo General PT Cruiser Discussions 28 06 Oct 2009 07:30 pm
airbox foam breather filter, DIY replacement ptandme General PT Cruiser Discussions 2 14 Oct 2008 11:34 pm
K&N filter oil on BTG filter? Punch Turbo Performance 1 15 Oct 2003 11:55 pm
Oil Filter Removal jramosGT Turbo Performance 12 03 May 2003 06:44 pm
  å¤–è³‡ç³»è»¢è· | Find services | Free All Ebook PDF Download | Barbara Boxer | Find services
