| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Mr Blond
That Should bee HP-2009 instead of HP-2900. Finders and head not working this AM.
<b><font color=\"red\">2003 LT ALMOND GT</b></font id=\"red\"> <font color=\"blue\">MODS:</font id=\"blue\"> Stage I, Custom Pin Stripe, Rear Spoiler, BTG Polished Strut Tower Brace, Borla 2.5\" CAT Back Dual Exhaust, and AirAid Intake System, Polished Front & Rear Sill Plates, Chrome Antenna Bezel w/10\" Chrome Billet Antenna, Mobil 1 and K&N Gold Filter, \"Flame\" 3rd Brake Light, \"Streamline Design\" PT Cruiser Visor, Rear Shelf Graphics and Dash Dots on Steering Wheel, and MGW \"GT\" Auto Shift Knob,Chrome Door Lock Pulls, Chrome Billet A/C Knobs with Acrylic Red Inserts, Chrome Oil Cap, Chrome Dip Stick, Chrome Radio Knob, Blane\'s Hood Lift Kit. Chrome Raidiator Coolant Bottle Cover, Timing Belt Housing Cover, Shock Tower Covers w/Nuts, Power Brake CYL Cap Cover, Windshield Washer Cap Cover, A/C Line Connector Cap Covers, A/C Check Valve Cap Covers and Radiator Cap Cover. \"GT2\" Rolo Red Calipers, Magnecor 8.5mm Spark Plug Wires - Red, Red Wire Looms, Billet Aluminum Steering Wheel Caps (4), Chrome Coin Tray Trim Cover, Chrome Shifter Bezel Tirm Ring, Yoko AVID V4S - 215/50/70\'s, TYC Euro Style Back-up Lights, and Screamin Demon Coil |
Thanks for all of the help, I just changed my oil for the first time today and everything went smoooth. I went with Mobil 1 5w30 and all i could find was a fram filter. When should I change my oil next? A couple of things I had heard was to change oil and filter every 8K, and another thing was to after 10K, change filter, then after another 10 K, change the filter and the oil.
![]() Now with stage 1 ![]() Just a GT... Thats tearin\' arse on the driveway. http://www.cardomain.com/id/themanfrmokinawa 14.626 @ 94.74 stage 0 , intake and exhaust only. |
I always follow the most severe maintenance schedule the factory offers in their owners manual. That means Schedule B and every 3,000 miles!
06 GT Auto, Cool Vanila Exterior, Presto Change O 3bl, Cargo Mat and Net, Billet Oil Cap, Yoko Avid 4Vs Tires, 03 GT Wheels, 4 Chrome Door Handle Screw Covers, MOPAR Mud Flaps, H&R Rear Sway Bar, Freedom Strut Tower Bar, Rear Door Sill Covers. |
I would never go 8k on any oil. Always a 2500 mile kinda guy. After my 2000 miles are up will run Castrol synth. to the 3 range though. Owning a harley, there was a huge debate over synth. and dino. After I broke in my rebuild , 1000 mile, dumped Casrol synth in and watched my oil temp drop 15 degrees. Also big debate on filters, had a link and will try to post it, a guy cut like all major filters apart to see construction and such. Fram took a big hit, and Wix was near the top. I will go with a Wix on my GT. Ohh, btw I use a ford FL1-A on my sportster, same specs on check valve and presure, just a half more quart of oil for the summer. and a whole lot cheaper than a HD replacement of normal size. The new Fram Tough Gaurd for synth oils with a new type of filter element is supposed to great and was not in the above guys post as it is really new. I will be dumping my first 1000 mile oil and filter this weekend, then dino and a Wix, dump at 2000, then Castrol Synth and maybe a K&N or Wix.
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge. Elbert Hubbard (1856 - 1915) 2003 Electric Blue GT- 30,000 Miles on the clock Stage 1, Mopar BOV, Brand X Air Box Pipe, K&N drop in, White silencer removed, Black lower silencer cut, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3 down pipe with high flow cat, BTG axel back exhaust, Rear Spoiler. Greddy Profec II B, Turbo Chargers Wastegate set to 13# Russel Brake Lines Hawk Brake Pads Power Slot Cyro Rotors Bag Stage II :-p |
I read a recent engineering article on the latest performance filters(you might do a search for it). Point is Fram (all of them), purolator, wix, and number of O.E filters.... all trash and prone to break.
Good ones... Mobil One filter, K & N. Buy a cheap filter...take your chances. |
I would go ahead and use the 10W30 mobil one, it won't freeze until -50 f or so, and in the heat 10W30 won't thin out as much as 5W30 will. Just my 2 cents
88 Daytona Shelby Z T-II Blue 88 Daytona Shelby Z T-II Silver T-Tops 89 Caravan ES Turbo-I 03 PT GT Turbo 41TE Autostick Electric Blue |
Reconsider 5w30. Today's engines are built to tighter specs and need thinner oil at first. City ran 5w30 in squad cars with no problems and those cars are NOT treated gently.
I'll run 5w30 to 50k then switch to 10w30. I changed the oil at 3k, 6k, and 10k. Based on senility, I change the oil at 5k intervals so I don't have to remember when it was what. It hits a 5k multiple, I just change it.[:I] |
This is the best I have seen on oil filters, and to us air cooled guys it is live or die with filters.
http://www.frankhunt.com/FRANK/corve...lterstudy.html
As for oil weights, the owners book says 5W30 or 10W30 are aceptable, with 5w30 preffered. However, the guide it shows for temps, and usage shows 10w30 for anything over 100degrees f outside, so for anyone that lives in a warm climate I would suggest that for sure.
As for tight clearnces, synthetics will thin out more than conventional anyway, so I'd rather use a heavier grade. Especially if I am gonna be drivng hard at all.
| Cabin air filter | AlmondTurbo | General PT Cruiser Discussions | 14 | 04 Apr 2008 06:46 pm |
| Whats up with factory oil filter | yotehunter | General PT Cruiser Discussions | 10 | 09 May 2005 08:28 am |
| Watch out K&N! | azptcruiser | Non-PT Discussions | 3 | 01 Apr 2004 11:55 am |
| K&N filter oil on BTG filter? | Punch | Turbo Performance | 1 | 15 Oct 2003 11:55 pm |
| Oil Filter Removal | jramosGT | Turbo Performance | 12 | 03 May 2003 06:44 pm |
