PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Tire /Wheel Question
Old 16 Sep 2003, 07:38 pm
GTPT GTPT is offline
Default Tire /Wheel Question
Does anyone have any ideas on any problems I may run into if I
install the following size tires and wheels?
18x7.5, 225/40R18, my car also has a 2" drop in the front.
Thanks for any ideas, Phil
Old 16 Sep 2003, 08:22 pm
bobs turbo pt bobs turbo pt is offline
this was posted by jody
I've got 215's and they're tight. TireRack says 225's won't work
Old 16 Sep 2003, 09:48 pm
Kirby Kirby is offline
If you want to be a hero, find a nice looking wheel that is of 17" or 18" dia. and 8" wide that will hold a 225 or 235 x 45 aspect performance tire. You must fit them into a lowered PT without grinding out the wheel wells, or having the tire fall off the rim. Pictures are a must!
This is your task, Manchester Man, if you choose to accept it. If you or any of your team is caught, we will disavow any knowlege. This mesage will self destruct in 10 seconds!
Old 16 Sep 2003, 10:32 pm
skylight's Avatar
skylight skylight is offline
Administrator
...that's on the stock rims.
Old 16 Sep 2003, 10:41 pm
PTGT Redman PTGT Redman is offline
Kirby,
I have a lowered cruiser with 17x8 Mille Miglia's.
They have 225/45 ZR17's on them with no rub or scraping.
See link below for pic's.
Homepage:
Old 16 Sep 2003, 11:58 pm
More pics, more pics!
Questions:
Offset?
Tires?
Old 17 Sep 2003, 04:03 pm
Kirby, they are the Dunlop SP9000's
The offset on my wheels is 35 degrees. I had them on my 01 but b/c of the wider front calipers, I had to add 3mm spacers on the fronts. Run great, nice ride.
Homepage:
Old 17 Sep 2003, 06:31 pm
So your ofset is 35 milimeters total? (I had a hard time with the degrees) -- (maybe you were thinking caster/camber settings).
Old 17 Sep 2003, 11:42 pm
Scuse, sorry...no 35mm.
Worked without a hitch on the 01,needed more front clearance on the turbo.
Homepage:
Old 21 Sep 2003, 04:42 am
silver srt silver srt is offline
you know, back in June I say a pt with 235 40 17 on it. I was walking by it at the show. And noticed that the tires were a little wider than I have seen on these cars. And they they were, 235's.
vB code is On
Largest size replacement tire for GT wheel is... Gary04GT Turbo Wheels/Suspension/Handling 12 01 Apr 2006 10:33 pm
Tire Accu-Pressure Safetly Cap Warning Curruzr General PT Cruiser Discussions 6 22 Aug 2005 07:46 am
widest wheels gonzomania Wheels, Tires, Suspension 11 27 Jul 2004 01:49 pm
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
GT Tire question don668 Turbo Wheels/Suspension/Handling 7 14 Apr 2003 05:53 am
  Advertising | Loans | Personal Loans | Free File Hosting 1 GB per file | Flights
