A little jerky
Old 06 Aug 2009, 11:18 pm
wachikinow's Avatar
Default A little jerky
Hey everyone! This is my first post here on the forum. I got myselft a GT a few months ago and I'm lovin it! Its an '04 with 66,000 miles. Somethin weirds been hapening not too long ago though. Whenever I floor it, It'll jerk a little bit a couple times as the rpms climb. I thought it was a boost leak cuz I have the Mopar BOV installed (it was fine when I first got it installed). I checked for a leak around the BOV but everything was fine.
Anyone know whats happening? Any suggestions would be great! Thanks
Old 07 Aug 2009, 12:35 am
Default Re: A little jerky
Have you done a basic tune up such as plugs and wires? I'd start there as the factory wires are known to cause problems.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 07 Aug 2009, 09:02 am
tandt14's Avatar
That definitely sounds like plugs and wires. My 04 Turbo lite did the same thing. No CEL in the beginning but it did eventually come on. If you have stock wires, upgrade them to aftermarket because the stock are garbage.
Old 07 Aug 2009, 09:07 pm
wachikinow's Avatar
Awesome guys! Thanks for your help. I'll change that crap out and see what happens.
Old 07 Aug 2009, 10:17 pm
wachikinow's Avatar
Does anyone have any suggestions on what kind I should get?
Old 07 Aug 2009, 11:47 pm
The Mopar performance wires aren't bad
Mopar Performance Ignition Wires 01-Up: Race and Street
Old 08 Aug 2009, 12:53 am
And NGK Iridium plugs. Just don't use platinums. Platinum plugs have been said to melt with the turbo engine!!!
Old 22 Aug 2009, 09:59 pm
wachikinow's Avatar
Haha yes!!! It worked! Shes runnin perfect again! Thank you so much guys!
Old 22 Aug 2009, 10:04 pm
Good. That's what it is most of the time...
