i replaced the intake manifold upper and lower gaskets on my wifes pt cruiser, everything went well got it all back together and it runs beautifuly but now it sounds like there is a big vacuum leak coming from the intake manifold but i cannot find it i even bought another set of gaskets and re did the whole procedure again and i cant figure out what it is, i sprayed ether down the intake tubes and the idle never changes any input would be great.
Dumb question here... did you check all the hoses? Also check the hose from the PCV to the intake. They have a bad habit of getting brittle and breaking.
yes i checked everything i took off i even took the whole thing back apart and put it back together again. it definitly sounds liek its coming from the intake down by the motor but it runs perfect no misfire no nothing
With out hearing it it's hard to say. Are you comparing the noise with the intake tube off or on? I don't want you to think I'm calling you dumb or anything. In a situation like this I usually find it's something very basic that I did wrong. Are you sure the bolts are tight and that the manifold is flat? When you put it all back together you have to tighten the bolts where the 2 pieces meet first and then the bracket in the back. If it's not flat then it can create a vacuum leak that will cause noise but not affect running because the leak is even in all cylinders. Also it doesn't take much of a leak for you to hear it.... These are the kind of things I have run into.
have you tried boost leak testing??
if you havent go to home depot or Lowes and buy a 2" plumming cap, go to autozone and buy a valve stem, poke a hole in the center of the cap and put the stem in, then get an air compressor and hook it up and fill the system with air and were ever you hear air comming out spray soapy water then fix the problem with zip ties or tighten the clamps or replacing the lines or gaskets.
Nevin. 03 SRT-4 — 132k mi ported stocker and lots of other stuff 68 Mustang Coupe — project fail!! PT Less - ex wife took in the divorce 3/2011 05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08 3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge |
| 02 Cruiser...Multiple Problems (1 odd/dumb question) | Silver02 | Tech & Performance Forum | 2 | 13 Aug 2008 05:09 pm |
| '02 Cruiser with lots of problems :( | slpknt2886 | Tech & Performance Forum | 4 | 07 Aug 2007 02:17 pm |
| 2003 Chrysler PT Cruiser GT Sport Wagon (lafayette / orinda / moraga) $9785 | skylight | craigslist | 0 | 24 Jul 2007 09:11 am |
| $500 cash allowance coupon on any 2003 Cruiser | TamzDream | Classifieds: For Sale/Trade | 0 | 01 Jul 2003 11:24 am |
| 2003 PT Cruiser | Sunrise | Tech & Performance Forum | 23 | 19 Feb 2003 12:58 am |
