HELP!!! Car cuts out at 2500 RPMS!!!!
Old 12 Aug 2009, 07:12 pm
Exclamation HELP!!! Car cuts out at 2500 RPMS!!!!
Hey guys i am new here so bare with me, you guys are a great help.
anyway i have a 2005 pt cruiser limited turbo lite. i have replaced the spark plugs and wires about a month ago, car has 48000 miles on it. so when i drive the car hard after about a mile of just cruising the check engine light comes on, and then the car is limited to 2500 rpms. now i pulled over and check the code which comes out to be 340 cam shaft error. as soon as i clear the code the car runs wonder full again with no problems what so ever. this has been happening for a week now. it wont come on at all until u drive it hard. thanks anything will help, i am thinking the computer might need to be flash. and MAYBE it needs better spark plugs. i don't think its the cam shaft sensor because would the car not start!!!. thanks.
2005 PT cruiser Limited Turbo Lite Auto, SCTflashed
Old 12 Aug 2009, 07:25 pm
Default Re: HELP!!! Car cuts out at 2500 RPMS!!!!
It still might be the sensor - starting to go and being temperature sensitive.
Also check the wiring to the sensor.
Here's where to find it:
Help! My Car Cut off while i was driving it
Old 13 Aug 2009, 05:37 am
Your in limp mode... It automatically does this to keep from blowing the motor.
Josh
AGP Billy boat 3"/S2 WGA/ MSD full ingition and control/ hallman MBC/ DCR 55mmTB/3" o2/Hurst STS/S2 injectors/ 30-30 boost/ wideband/ MP inserts/ Booger bushings/ Rage tuned DSP/ 22psi 18psi to Redline/ Mopar rice plate (no leak)/ K&N cai with heat shield/
Help Rough Low Idle almost cuts off.. lockupman1 General PT Cruiser Discussions 10 10 Nov 2008 08:17 pm
Engine cuts in and out at 2200 RPM tomrinsb Tech & Performance Forum 21 13 Oct 2008 04:50 pm
GT PT will not go over 2500 RPM jerrys Turbo Performance 6 20 Aug 2008 09:35 am
Stumble at 4k rpms in neutral 05CruisergtHO General Turbo Discussions 1 24 Apr 2008 03:26 pm
radio/cd player cuts out gonzomania Sound and Security Forum 25 26 Nov 2006 12:16 pm
  Millsberry | Wordpress Theme | Wordpress Themes | Debt Consolidation | Debt Consolidation
