TURBO HOT!!!
Old 18 Aug 2009, 08:33 pm
Talking TURBO HOT!!!
i just tune my stock pcm with the SCT tuner, i did the transmission learn, and DAM can that thing move, wow then i pulled over cuz it smelled like something was burning not bad just a little and when i opened the hood the turbo was so REDDDD i was like omg fire!!! but then i was like wait this is ok, lol any suggestions tho on how to keep that turbo cool!!!.
2005 PT cruiser Limited Turbo Lite Auto, SCTflashed
Old 18 Aug 2009, 11:41 pm
Default Re: TURBO HOT!!!
You could run some kind of duct to it. I wouldn't really worry about it. Too bad the PT didn't get a hood scoop like the SRT-4. The scoop runs right to the turbo and cools it.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 19 Aug 2009, 11:38 am
wheelgarage's Avatar
Driving a turbo'd engine hard will cause the exhaust pressure side to "glow". The only thing to do is to allow it to cool internally. DO NOT shutdown the engine immedately after very heavy-hard driving. Make sure you are running synthetic oil and use a type of Redline Water-Wetter (addition cooling additive).
The other thing to keep the heat from bleeding into the car or burning up the heat sheild is to invest in an upgraded heat sheild/wrap and a down tube wrap. That will keep the engine compartment cooler.
2005 Touring Black - Automagic....
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | OEM Rotors | Akebono Ceramic Pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In
Old 13 Jan 2010, 11:04 am
ROCKETMAN8060's Avatar
Exhaust Heat Wrap Installation
This is just a example of the wrap that Wheelgarage is talking about!! Good luck!!
ROCKETMAN8060
Old 13 Jan 2010, 01:45 pm
I wouldn't wrap the turbo. It needs to cool of or you'll really coke up the oil. After some hard use at night the turbo will glow bright red.
Old 14 Jan 2010, 03:18 pm
chris15's Avatar
I agree with Mean Green on this one, I personally wouldn't wrap it.. the heat needs to dissipate from the turbo..
I know running lean will also result in heating up your turbo, but you didn't mention tweaking a/f ratios, so I wouldn't worry about that.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
Old 27 Jan 2010, 03:04 pm
Just to be aware, the turbo will also glow if the exhaust system has a blockage in it and it doesn't flow right.
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Stage 1 Kit official or aftermarket? vash382 Stage Turbo Kits 30 03 Jul 2009 03:58 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Many Questions on turbo function! dgc333 Turbo Performance 2 09 May 2003 03:36 pm
