pin hole leak at turbo's coolant line
Old 21 Aug 2009, 12:41 am
Default pin hole leak at turbo's coolant line
hi all -
i smelled coolant all day today while running errands. i kept thinking it was the car in front of me.
when i got home this evening i discovered a pin hole leak at the rubber hose portion of a small coolant line - the one that leads directly to the turbo. it was a tiny, tiny pulsing mist. the rubber hose section of this turbo's coolant line is just to the left of the airbox. it's in very close proximity to the coolant sensor (i think it's the coolant sensor). i had to remove the airbox to get to this hose.
the hose that had the leak, is one of those crocked "S" pre-shaped hoses (my guess - a dealer-only item - $$$$).
anyway, if this happens to YOU --- save a few bucks and do it yourself.
Replace the fancy-pants stock hose with a 3/8 ID, 1/2" OD fuel line, cut it to size (make sure it does not kink), and reuse the existing factory quick clamps. add a few splashes of 50/50 coolant to the coolant recovery bottle.
there, you just save $900 dollars that the dealer would have charged you
Old 21 Aug 2009, 12:08 pm
wheelgarage's Avatar
Default Re: pin hole leak at turbo's coolant line
I personally do not have a turbo version, but have experience with turbo systems. My past turbo's always ran a braided line into and out of the turbo.
Either replace it with the original or upgrade it with a coolant specific SS braided line. Also, sleeve it with a heat resistant tube or wrap. The turbo can get excesively hot, so protection is key for longevity.
2005 Touring Black
H&R Cup Kit
TSW Sakata 18x8 35ET
Toyo Proxies 225-40-18
K&N Drop-In
coolant leak from the radiator drain geronimo Tech & Performance Forum 1 19 Jul 2009 02:55 pm
NEW 2007 Cruiser had a leak in fuel line stacigw General PT Cruiser Discussions 1 20 Nov 2007 09:52 pm
Turbo oil return line leak littleblueGT General Turbo Discussions 3 11 Sep 2007 07:38 pm
Oil Cooler Line leak dpj450 General Turbo Discussions 1 24 Jul 2006 03:50 pm
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
  Debt Consolidation | Debt Consolidation | Find jobs | Wordpress Theme | Wordpress Themes
