"Wet" Plugs
Old 24 Aug 2009, 10:33 am
BB BB is offline
Cool "Wet" Plugs
2003 Turbo with 87,000 miles on it. 27,000 miles since last plug change. Removed the plugs this morning to install new plugs...threads on 2 were covered with oil. Threads on one were dry on the tip half but "wet" on the top half. Threads on the 4th plug were dry. Does this mean anything?
Thanks!
Bill
P.S. The oil(?) is *only* on the threads...nothing on the tips or electrodes.
BB
\'03 Stone White GT
..with a little chrome..so far
Old 24 Aug 2009, 05:29 pm
wheelgarage's Avatar
Default Re: "Wet" Plugs
If the PT's have individual seals for each plug hole (where the cover meets the head), those could be leaking. I'm guessing here...never experienced this with a PT yet.
But, I did have similar issues with other DOHC engines....
2005 Touring Black - Automagic....
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | OEM Rotors | Akebono Ceramic Pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In
Old 24 Aug 2009, 06:29 pm
chris15's Avatar
If oil's on your plugs, it typically should be seen on the tips as well.
Have you personally done all the work on your car? Sure it's not just crappy dielectric grease?
Alternatively, have you checked your PCV valve? Oil in your combustion chambers could be the result of a plugged PCV valve causing an increase in crankcase pressure, pushing oil past your rings.. If your PCV valve is functioning properly, you could have one or more worn piston rings or could be your valves.. best thing to do is a compression check to rule either of those out.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
Old 24 Aug 2009, 08:45 pm
BB BB is offline
Just the easy stuff! Hadn't thought of that!! Maybe that's all it is since the tips are clean.
Yeah...I'll have to check the PCV valve...maybe find someone to do a comp test too. I'm hoping it's just the grease!
Thanks!
Bill
BB
\'03 Stone White GT
Old 24 Aug 2009, 08:48 pm
BB BB is offline
Not positive but I think there are individual seals. Hmmm...more research needed...
Thanks!
Bill
BB
\'03 Stone White GT
Old 26 Aug 2009, 03:46 pm
nevinsrt's Avatar
it could possibaly be a worn spark plug gasket on the valve cover. oil could just be seeping through and down the tube and as you unthread the plug oil is getting on the plug.
Look down the plug hole and if there is oil then that may be the problem. if you buy a new valve cover gasket you will see 4 circle gaskets, one for each hole. the gasket is easy to replace.
EDIT:
Felpro Valve Cover Gasket Set Dodge Neon SRT-4
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 29 Oct 2009, 08:32 pm
I had the same problem with my 04 turbo, it turned out to be the seals in the valve cover where the spark plugs go in. The oil leaks from the valve cover into the spark plug. I'm willing to bet that it stalls on a foggy morning. Just get a valve cover gasket kit. Make sure you know the engine vin number. Godd luck.
Old 30 Oct 2009, 07:04 am
EDIT:
That's my bet as well.
Old 31 Oct 2009, 03:25 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
VS50459R by felpro. run ya about 26.00
if you need R&R instructions pm me as i have an alldata account.
available at any auto parts store.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
E3 Spark Plugs Ceit Turbo Performance 4 27 Nov 2008 11:09 pm
3/25/05 UPDATE - DONE! - New Plugs and Wires NGK BumperBob Tech & Performance Forum 14 31 Mar 2005 01:06 am
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Spark Plugs kidturbofan Turbo Performance 2 08 Oct 2003 10:40 pm
