Turbo Question
Old 24 Aug 2009, 08:59 pm
grungerockjeeper's Avatar
Default Turbo Question
*total noob question alert*
I recently purchased a used '03 GT 5spd. I read somewhere that turbos need to 'idle down' before you kill the engine, especially after hard driving. What kinda time are we talking for a PT, and how hard do you have to run it to require this?
Common Sense. So rare and uncommonly practiced that it now qualifies as a freakin' super power!
'00 Jeep Wrangler Sport: 2" BDS lift and swaybar disconnects, 32" BFG a/t's on Eagle 10-hole wheels. Fabtech front bumper, K&N cold air intake.
'03 PT Cruiser GT 5spd: removed muffler and airbox silencer future planned mods are K&N typhoon intake, 2" rear lowering springs, hopefully some kind of old skool mag style wheels, and possibly at least a stage 1 turbo upgrade. Oh and i GOTTA get rid of those $#@!'in flame decals!
Old 24 Aug 2009, 09:15 pm
Default Re: Turbo Question
Running it hard, freeway driving or towing you need to keep it running and cool it down a few minutes. The manual specifies the exact time needed. Normal driving needs no cool down. After hard driving and then going to normal driving for a few minutes or longer constitutes cooling down time.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 24 Aug 2009, 09:56 pm
Chromenut's Avatar
When I've run mine hard, which is quite often, I get off a the exit 2 miles from my house instead of the one down the street, then I baby it home.
Think of it like walking a horse after running it, you have to let it catch it's breath and get the lather down before stabling it or you can cause all kinds of troubles. I drive from Atlanta to my house, a little over 4 hours, and about 3 miles before home I slow down and drive like a human, by the time I'm home it's good to go.
Old 24 Aug 2009, 10:33 pm
Good plan.
Old 25 Aug 2009, 03:16 am
Ok cool. So if Im hauling it on the way to work, I just need to get out of it a bit before I get there to let it rest up. Makes sense. And I gotta tell you, the good info flows like wine on this forum. You guys rock!
Old 25 Aug 2009, 05:35 am
And put synthetic oil in that engine!
Old 25 Aug 2009, 03:20 pm
any recommendations on oil brands? Ive been a fan of Castrol for many years, although Pennzoil is a good choice also. Im definitely gonna grab a bottle of slick 50 since Ive used that in all my jeeps, works great.
Old 25 Aug 2009, 04:49 pm
I think any name brand full synthetic is fine.
I'd stay away from "blends" - I have never seen what % of a "blend" is synthetic - 2 drops?
Old 26 Aug 2009, 09:10 am
Don't ride'r hard and put'er away wet!
Old 26 Aug 2009, 03:36 pm
nevinsrt's Avatar
hahaha my cool down time on both cars is waiting for the light to turn green so i can turn on base, sit and wait for the guard to look at my ID and ask about the car, drive 3/4mi at posted speed of 15mph. takes me about 4-6mins
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Question on 07 Vert Turbo CREWZIN General Turbo Discussions 7 24 Oct 2008 11:23 am
Question about my Turbo. JMan General Turbo Discussions 4 18 Mar 2008 07:35 am
Turbo Brake System Question R_I_PT Turbo Wheels/Suspension/Handling 5 03 Nov 2007 07:44 am
Turbo manifold question proxeyed Tech & Performance Forum 6 29 Jan 2005 12:55 am
