Changing spark plugs 2005 GT aluminum manifold
Old 27 Aug 2009, 01:34 am
dsmturbo's Avatar
Default Changing spark plugs 2005 GT aluminum manifold
Okay, I was following chris's excellent instructions on changing the spark plugs and wires.
I could not for the life of me get the plug wire off the 1st plug, I twisted and pulled and did it again and again. It seemed to pop a bit, but dam thing wouldn't come off. So, as I didn't have the new wires as yet, I didn't want to risk breaking the wire.
How would I go about trying again to remove the plug wires? Any ideas?
2003 PT Cruiser GT, turbo, Inferno Red Pearl, autostick, 84K, MSD 8.5m wires, NGK iridiums
Old 27 Aug 2009, 08:13 am
Default Re: Changing spark plugs 2005 GT aluminum manifold
I would say wait 'till you get the new wires, then twist and turn and yank (and curse).
Be sure to use dielectric grease on the plug boots and plug ceramics and a dab of anti-seize on the plug threads so next time you don't run into the same grief.
Old 27 Aug 2009, 09:32 am
Send a message via AIM to fljohnboy
I had same problem when recently changed my plugs. I used a long pair of needle nose pliars right on the boot of the plug wire where the plug and boot meet. It came right off.
Old 27 Aug 2009, 10:55 am
Try pushing down and twisting slightly to break the grip, then pull; that worked for me.
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 27 Aug 2009, 12:02 pm
dsmturbo's Avatar
Thanks for all the tips, yes I thought of using long needle nose, but I'll wait until I grab the wires, should be in today.
I will be using grease and anti seize. I know the old DSM's we had were sometimes a B@@ch to get off as well, but I have never had this much trouble LOL
Old 01 Sep 2009, 07:02 pm
Antisieze no longer needed. Most plug manufacturers now imploy the use of antisieze coatings on their plugs as well.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 01 Sep 2009, 07:41 pm
I'll still put on a dab...
Old 01 Sep 2009, 09:44 pm
dsmturbo's Avatar
Originally Posted by jerseymike68 View Post
nice sources here
Not sure what you are referring to jerseymike
Old 02 Sep 2009, 01:13 am
I believe they make tools for this. Looks like a screw driver with a half moon on the end.
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
Old 02 Sep 2009, 12:34 pm
dsmturbo's Avatar
I'm sorry, a tool for what?
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
CHANGING SPARK PLUGS & WIRES?? mjb457 Tech & Performance Forum 10 21 Oct 2009 03:01 pm
Oil Dipstick Difference When Changing from Aluminum to Composite Manifold intim3 Turbo Performance 5 23 Apr 2009 06:18 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
Changing spark plugs yourself mps General PT Cruiser Discussions 9 14 Oct 2004 12:05 am
