Stop Turbo from turning?
  #11 (permalink)
Old 30 Sep 2009, 12:37 am
Default Re: Stop Turbo from turning?
Originally Posted by quicksilverdon View Post
I cannot think of anything else than it can't be getting oil... I know you said you cleaned the lines....
If you have no other clues, try PTCrew.Com - lotsa turbo gurus there...
Thanks. Shouldn't the Turbo last more than a few minutes without oil flow. I would think it would take a couple hundred miles of driving before it destructs.
It's getting oil. I removed the drain line hose at the bottom and placed the end of the line in an oil can. Started the motor. The oil is making it through the Turbo. How much oil flow does it require? Example: A steady oil flow as if you open a drain plug. A fast drip or a slow drip.
  #12 (permalink)
Old 30 Sep 2009, 12:17 pm
A few minutes, at the temps a turbo gets, I would think is enough to cook it.
If you're getting oil, then I don't know why it died.
You might try PTCrew.Com - more turbo gurus there...
  #13 (permalink)
Old 30 Sep 2009, 01:24 pm
Even without the oil flow, it's cooled by engine coolant. I would think that would take care of the heat issues until the bearings give out.
Thanks for the help and I'll check out PTCrew. If I get it figured out, I'll get back with feedback.
  #14 (permalink)
Old 01 Nov 2009, 12:09 pm
Update.
Turbo was changed without changing the exhaust manifold. The alignment pin was in a different location. This made the wastegate actuator arm bind and so the internal wastegate was not working as it should. This caused the Turbo to overspeed and cause the bearings to fail.
  #15 (permalink)
Old 02 Nov 2009, 09:05 am
Thanks for posting back with the cure - I haven't heard of that problem before....
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Stage 1 Kit official or aftermarket? vash382 Stage Turbo Kits 30 03 Jul 2009 03:58 pm
will wraping the turbo pipes stop balloning mino General Turbo Discussions 2 11 May 2008 04:49 pm
2003 PT Turbo Review by AUTOTEST FILE Gary04GT General Turbo Discussions 2 12 Jul 2003 09:14 am
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
