Both interior Power Outlets...the unswitched ones front and back...have no juice. I know for sure the front one was working two days ago because I always have my cell phone charger plugged in and it has an LED that shows it has power. Today...nothing. So I figured I blew the fuse somehow. Checked fuse #19 under the hood and it's good. What should I check next?
Thanks! Bill
BB \'03 Stone White GT ..with a little chrome..so far |
There also another fuse block under the steering wheel. I forget which circuit those are on. (I think the unswitched ones run first through IOD, then via accessory? I'm probably wrong)
Thanks! Bill
Found this on PT Do-It-Yourself.net:
Recheck fuse #19 (20amp) in the PDC. If it's ok and both power outlets are dead it's most likely an issue with the circuit wiring. It is not likely to be the ignition switch since the front power outlet is always hot regardless of ignition switch position and the rear power outlet is controlled by the ignition switch.
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 100,000 miles, Original Owner Visit My Home Page www.CREWZIN.com |
Quick update:
Pulled dash to access front Power Outlet. Had 12V on connector that attaches to the back of the plug. Inserted and removed connector several times to get rid of any corrosion that might have caused the lack of power. PO works fine now. The rear PO still doesn't work. I'll have to pull that panel and try the same fix back there. Bill
| Power Outlets | newcruiser123 | Tech & Performance Forum | 8 | 17 Mar 2009 08:29 am |
| 2008 lineup saves on fuel, but not power | skylight | PT Cruiser News and Rumors | 0 | 13 Oct 2007 04:09 pm |
| Guide: 2006 Power windows and Sunroof always on. | zapwizard | General PT Cruiser Discussions | 3 | 21 May 2007 09:23 am |
| auxilliary power outlets | R.E. | General PT Cruiser Discussions | 16 | 19 Oct 2004 02:06 pm |
| Optional Power Outlets | Hooligan | Tech & Performance Forum | 6 | 16 Aug 2003 05:57 pm |
