Engine codes godsend :)
Old 29 Sep 2009, 11:03 am
Default Engine codes godsend :)
Just as I was about to hop on the freeway for my 90 mile round trip commute this morning, my engine light blinked several times. I did a u-turn so as not to get on the freeway and pulled into a parking lot. Nothing noticeably wrong with the car. Idle was fine, etc. I decided to drive on in to work and did so without incident.
I read a bunch of threads about error codes on this board. I've also bookmarked that sticky with the list of codes. I'll be retrieving the codes when I get home and will look them up here to see what's going on. I just crossed 40k miles, so I'm hoping it's just a service that's overdue. I just wanna thank you guys for the wealth of info you keep here on the site. I can think of three separate times when I was able to fix some small thing myself rather than take it to the mechanic because of what's already on this board. It's a great resource.
Wish me luck tonight!
Old 29 Sep 2009, 11:43 am
nevinsrt's Avatar
Default Re: Engine codes godsend :)
what was the code? did you do the key dance?
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 29 Sep 2009, 11:46 am
Why wait 'till you get home? Only takes a minute...
Old 29 Sep 2009, 09:36 pm
I waited until I got home because I park in a busy garage in the morning. No time to sit in the car. The parking guys grab it quickly and get it out of the way.
Unfortunately, I couldn't get a code. I tried half a dozen times. I always got it to return "done", which I think means I did the sequence right, etc. I'll try again in the morning, but I did it as fast as I could this evening.
Old 30 Sep 2009, 12:07 pm
Sometimes, it does not store a code....
If it doesn't recur, forget it.
Old 30 Sep 2009, 02:27 pm
Well, I was overdue for new plugs and wires and so I took it to the mechanic and had that done this morning. I was going to get an oil change this weekend anyway, so I added that to the list. I'll just hope that it doesn't come back.
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
Engine overheating, Stuck in "Limp mode" showing codes 0188,1490,&1495 Manny Tech & Performance Forum 4 08 Apr 2009 05:39 am
2005 pt overheat no engine codes bettyblup Tech & Performance Forum 5 21 May 2008 02:06 pm
Engine Light Codes Rob in tx Tech & Performance Forum 2 06 Mar 2005 03:55 pm
Engine codes Kroozah Tech & Performance Forum 8 31 Jan 2005 01:22 am
