Installing a Block Heater in a Turbo PTC
Old 10 Oct 2009, 07:09 am
Default Installing a Block Heater in a Turbo PTC
I live in Canada, recently bought a 2007 PTC Turbo 2.4 litre. I have to install a block heater. I will take it to a garage to have installed but wondering if anyone has any comments / suggestions.
I am installing command start as well. When the windchill is -50 degrees, we need help starting our cars.
After having the car checked at a local Chrysler dealership, a ridge is wearing on the rotors and a front control arm bushing needs replacing plus rear bushings are loose. With this car being only 2 years old, should I be finding these type of repairs???
Old 10 Oct 2009, 07:20 pm
Default Re: Installing a Block Heater in a Turbo PTC
I thought a block heater was a factory option - that would be the way to go.
Ridge in a rotor? So what? I always find ridges in rotors - first application of brakes and the brake pad will conform.
A suggestion is to replace bushings with polyurethane - they are much better.
Old 15 Oct 2009, 11:04 am
nevinsrt's Avatar
Dammm thats cold!!! i know the coldest ive been is -38 and thats nothing compared to what your saying LOL.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
Old 15 Oct 2009, 06:46 pm
Me thinks she is quoting Celsius not Fahrenheit!!!
Old 15 Oct 2009, 07:02 pm
Doesn't matter. -40 is the same in Fahrenheit & Celsius.
Old 22 Oct 2009, 08:19 pm
Location: Belleuve, WA from Los Angeles - Road Rage specialist
Where she is from she needs it..
Mopar does have one in the options list.. Strange to see a Canadian spec car not have one.. All the cars my honey has ever driven have had it.. And he's from Vancouver!
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
Wanted: Turbo block only!!! 340x Classifieds: Want To Buy 4 23 Jun 2006 05:40 pm
Installing a Turbo guage crazie.eddie General Turbo Discussions 1 30 Aug 2004 11:17 am
block heater newbie? Punch General PT Cruiser Discussions 6 16 Jan 2004 12:33 am
engine block heater SteelBlueGT General PT Cruiser Discussions 4 25 Oct 2002 06:33 pm
