Junk Yard would be perfect and if you go to srtforums.com there is always good turbos for sale. Do note that about $1500 can be spent but you will get everything
Check out my Web page: http://ptcruisernetwork.ning.com/profile/theshadow http://orangecountycruisers.org/ |
Sounds like you have a really nice ride. I hope you haven't gone rice and put a srt emblem on your car.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
The mbc runs off the selinoid (i'm a chef not a speller!) which is vacuum lines... If the mbc is all the way closed (no boost) it dosent reduce the stock diameter of the line... Ie you will run stock boost! The wga is an exhaust bypass system, allowing air to either go to the turbo or out of the exhaust. As pressure builds so does the tension on the spring holding the valve closed. The stock valve starts to open at 4psi and is fully open at 9-10psi. Agp wga, S2 wga, and fm wga begin to open at 9psi unless you upgrade the spring. The advantage of the non stock wga is a shorter arm= the larger the distance between the valve and the spring is greater tension or more boost! No after market wga has a longer than stock arm... Which means... Wait for it... Stock boost! You may have run 5psi but not for the reasons above. On a side note, i did a little digging on your car... Nice work! That takes alot of detication. Josh
AGP Billy boat 3"/S2 WGA/ MSD full ingition and control/ hallman MBC/ DCR 55mmTB/3" o2/Hurst STS/S2 injectors/ 30-30 boost/ wideband/ MP inserts/ Booger bushings/ Rage tuned DSP/ 22psi 18psi to Redline/ Mopar rice plate (no leak)/ K&N cai with heat shield/ |
The PT seems rediculously easy to turbo, especially with available bolt on parts from donor cars (read SRT4) and if you do your own ECU you can really keep the costs down.
All that said, I wouldn't venture into it if you aren't that mechanically inclined or of you need to rely on your PT for anything. It takes time and knowledge as well as a couple bucks. You could probably pull it off for around a grand if you source the right used parts. I may turbo my PT at some point after I toss one on my TJ. Gas mileage improvements are nice, however they get really god with the right tune and ECU. On my Probe GT for example once I turbo'ed it I was getting 7 more MPG on the highway as well an extra 100+ whp.
No wga is longer than stock... If you dont know, dont answer... Do research
I don't want to get into a turbo war with you here, I have ordered custom rod length wastegates for years in custom fab canisters as well as extended threaded rod canisters myself with turnbuckles.
And don't assume I do not know or have not researched; 20 years of building cars, having a speed shop and building quite a few turbo setups should lend me some credence here. If you don't know, don't insert random words - research. This is not rocket surgery.
Can you turbo a pt cruiser that is non turbo... yes but not by simply bolting on and going. If you haven't customized your car and its in good condition, trade it in and get a gt then get the stage 1 from mopar call it a night and enjoy the car.
| why is the turbo so quiet on the GT vert? | vrracing | PT Cruiser Convertible Forum | 1 | 24 Apr 2009 01:33 am |
| Question on 07 Vert Turbo | CREWZIN | General Turbo Discussions | 7 | 24 Oct 2008 11:23 am |
| GT vert Turbo | careyk | General PT Cruiser Discussions | 8 | 21 Apr 2008 11:51 pm |
| WTB: '06 or '07 'vert TURBO with a 5-speed | teahead | Classifieds: Want To Buy | 0 | 11 Apr 2008 12:02 am |
| New PT vert pics...... | TexasCruiser | PT Cruiser Convertible Forum | 1 | 09 Jul 2007 07:46 pm |
