Idle vibration...
Old 05 Nov 2009, 07:30 am
Default Idle vibration...
I've asked before and headed the advice: I've checked all the hoses, changed the plugs and wires, even zipped all the hoses with no change in the idle vibration. It's enough to be annoying and can see the back of the hood bounce (I installed a rubber grommet to hold it more secure, just 'cause).
The motor mount looks good, other than that...
Any other suggestions???
2005 Limited Turbo-Lite, auto in Cool Vanilla
Old 05 Nov 2009, 06:03 pm
Default Re: Idle vibration...
Clean the idle air controller - right behindthe throttle body - do a search on IAC.
Old 05 Nov 2009, 10:32 pm
soonercruiser's Avatar
Cool Re: Idle vibration...
When's the last time you changed plugs & wires?
(Lack of information makes our guesses bad)
Frank, aka SOONERCRUISER,
Old 06 Nov 2009, 11:24 am
He said he just replaced them, but I wonder if they were gapped @ .040?
Old 06 Nov 2009, 11:27 am
Plugs and wires within 3-months, pulled them and re-gaped to .035 a week ago. Yes, I've cleaned out the throttle body, intake and the manifold when I re-gaped - wasn't that bad. Air filter is good.
It seems to run fine, just the idle is rough.
Old 17 Nov 2009, 04:51 pm
you might take a look at your torque struts. I found both of mine broken and when I replaced them it stopped.
Old 17 Nov 2009, 06:40 pm
And, there's more than 1 mortor mount, isn't there? He said he checked "motor mount".
Idle vibration garner49 General Turbo Discussions 11 07 May 2009 09:17 pm
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
vibration ? 2004PTCruiser Tech & Performance Forum 16 05 Jul 2008 09:40 am
Vibration between 40 & 60 mph???? anyone had this? gtbright General Turbo Discussions 10 16 Jul 2005 03:06 pm
Vibration!!!! 2003ptcrusierbrusier Tech & Performance Forum 8 05 Jan 2004 08:45 pm
