fan doesn't work but doesn't overheat
Old 05 Nov 2009, 07:48 pm
Default fan doesn't work but doesn't overheat
any ideas?
the fans do not run thru their test cycle each time the motor is started (had the hood up and watched/listened)
the temp gauge stays in the middle
the fan does run when the a/c is turned on
my Haynes manual refers specifically to relays mounted to the radiator on turbo models and I see 2 boxes that look like relays on the driver lower corner below the battery
think it might be the relays or the temp sending unit (where is it located)
thanks for any input, I did search overheating, fan, coolant fan, relay and couldn't find anything to help
Old 05 Nov 2009, 10:10 pm
Default Re: fan doesn't work but doesn't overheat
What is your problem? If it's not overheating! The fan shouldn't run when you first start the car unless the A/C is on and that's exactly what it's doing. What's the thing about a fan test cycle, where did you read about that?
Old 06 Nov 2009, 10:50 am
If the fan doesn't come on when the A/C is on, it's only a matter of time before it'll overheat.
Usually it is the fan that has died.
Old 07 Nov 2009, 10:20 am
I think I read on this site about the fan test. My car has done it since the day it was new. About 10 to 15 seconds after starting the car the fan runs thru a low speed and high speed test (lasts about 10 seconds).
Anybody else with an 03 GT tried starting the car with the hood up and gone to the radiator and listened for the fan? I can even hear it with the hood closed and the windows cracked.
The problem is not overheating but the fan does not cycle anymore.
I'm not running the a/c but if I did the fan does work normally
Guess I have a super cool car, even after driving home from work and leaving the motor running for half an hour the temp still didn't go past normal and fan didn't come on once (I was outside listening)
Hope I solved overheat prob. Arne Tech & Performance Forum 11 14 Oct 2009 10:14 pm
pt gt almost overheat/oil press.light help mtnbktrek General Turbo Discussions 6 01 Feb 2009 09:51 pm
Overheat problem fixed!! (I hope) Deano Tech & Performance Forum 5 20 Aug 2008 05:39 pm
2005 pt overheat no engine codes bettyblup Tech & Performance Forum 5 21 May 2008 02:06 pm
overheat onyx pt General Turbo Discussions 11 27 Nov 2006 10:55 am
