factory trans fluid color when new?
Old 29 Nov 2009, 04:33 pm
Default factory trans fluid color when new?
hi all -
just finished changing my trans fluid. i put 5 quarts of castrol atf+4 full synthetic (for use in chrysler vehicles) $$$$ and a new filter and o-ring. after a test drive and fluid check all is well.
my old trans fluid (with 55,670 miles) was a milky brownish color. the new fluid is red.
my question is:
since the old trans fluid didn't look that bad to me or smell burnt (just funky), what was the color of chrysler's factory trans fluid - when new?
was it light brown or red (like this castrol stuff)?
if it was originally red, then this trans fluid was probably - almost baked.
if it was light brown to start with, i probably did not have to change it, use a half a bag of oil dry, go through 4 rags, and ruin one decent t-shirt.
gt model, modified airbox with cold air induction, magnecor plug wires, tyc b/up lenses, chrome grille kit, retro 3d taillights painted steel blue, buick-style portholes, nomad chevy trunk trim, blue interior light strips, and massive turned down diesel-type exhaust tip.
Old 29 Nov 2009, 05:00 pm
Default Re: factory trans fluid color when new?
I've never seen any color for tranny fluid than red. If this is an auto tranny and it was milky brown you have my condolences. 55k+ is way too long to change the fluid. For the auto tranny every 30k you should alternate between a full service flush and a drain and fill. If you have the auto tranny and you didn't do a full service flush then you just mixed old fluid with new. Even for the manual tranny 55k is is too long to wait for a change.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 29 Nov 2009, 06:09 pm
appreciate the reply mean green and thanks for your condolences. you know, most people never change their trans fluid and filter - and most of those transmissions perform well past 100K miles.
life is too short and this car's resale value is too low to go to the trouble (and expense) of a full service flush, so i feel good about changing mine out - even though this preventive maintenance task was 25K miles past due.
keep on truckin'
TRANS FLUID TYPE? ptTurbo528 Tech & Performance Forum 14 28 Sep 2016 12:02 pm
synthetic trans fluid ok? 85_305 Tech & Performance Forum 11 24 Jul 2009 11:41 am
trans mission fluid|? whipplep General PT Cruiser Discussions 7 30 Sep 2008 06:14 pm
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
