41TE Upgrade Kit
Old 16 Dec 2009, 08:28 pm
SilverSleeper's Avatar
Default 41TE Upgrade Kit
Hey does anyone know where I can find an upgrade kit for the 41TE tranny ? Iv asked this before on ptcrew.com but I lost the link, I know the kit is around $1100, has anyone done this yet ? what did it cost to have the kit installed ?
Old 16 Dec 2009, 08:40 pm
Default Re: 41TE Upgrade Kit
Did you do a search on PT Crew to see if you can find it again? No one here has talked about an upgrade kit. The owners over at CREW are into performance more than they are here and are willing to put that money out to try and keep the tranny from going out because of the HP they are putting out.
If you don't beat it, and keep up with preventative maintenance, the tranny will stay together just fine.
Old 16 Dec 2009, 08:43 pm
Actually I just now found it
[url=http://www.ptcrew.com/phpBB2/viewtopic.php?t=8749]
The reason Im asking is bc Im fixing to install my S1 kit and I would like some added strength to the tranny
Old 16 Dec 2009, 09:24 pm
Very wise precaution...
Old 17 Dec 2009, 10:47 am
chris15's Avatar
For $1100 you could do a 5-speed swap into your car and completely do away with the 41TE, as it's a shit tranny anyway. Even fully built up, it won't handle more than 300whp on a daily basis.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 17 Dec 2009, 05:21 pm
Well that may be but I dont plan on going over 300whp, stage 1 only puts at what 200-210 whp, thats still a long ways to go, and shifting gears all the time is a big pain in the ass. Id consider a manual swap if and when I plan to go over that limit. I wonder if you can add one piece then later do another with the upgrade I.E LSD first then wait to do HUD assembly then torque converter or any order I choose
03 GT: Mopar S1,DSP 93 Oct Tune,Composite Manifold,AMX UHP & LHP,Needswings DP with 3" Cutout,AEM Intake Into Modded Stock Air Box,Mopar BOV,Triple Pillar Pod Setup ( Boost Controller,Wideband,Oil Press),Rota Boost 17" Gunmetal Metallic,Nexen N 3000 Tires,Eibach Lowering Spring Kit W/ Tockico Shocks And Struts,HID's,Blacked Out Tail Lights.
( Awaiting Installation: AGP DogBone MM,GodSpeed FMIC )
Old 17 Dec 2009, 10:27 pm
Oh yeah, that's why the 41TE went out in my '01 150 hp PT at 81k even with dealer preventive maintenance. The 41TE is a weak link. Most don't have a problem, but a lot do. It's the luck of the draw.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Turbo upgrade wmiptguy General Turbo Discussions 5 13 Apr 2009 04:15 pm
41TE Trans. Solenoid Pack, I have 2 part #s??? sknight88 Tech & Performance Forum 10 16 Nov 2008 04:49 pm
upgrade my ecu jlamoros Tech & Performance Forum 10 12 May 2005 12:46 pm
BOV Upgrade Kit Fast04PTGT Turbo Performance 11 23 Nov 2004 04:12 pm
41TE torque rating twallyf Tech & Performance Forum 5 28 Jul 2004 10:13 am
