Whistle Sound when warm starting
Old 28 Dec 2009, 07:23 pm
dsmturbo's Avatar
Send a message via MSN to dsmturbo Send a message via Skype™ to dsmturbo
Default Whistle Sound when warm starting
I am getting a weird whistle sound when I start the car when it is warm, and the sound can last from 1 sec to about 3 seconds. I think it might also make it sometimes when driving but I haven't checked that as yet.
It appears to be coming from somewhere around the intake, behind it, or nearer the right side engine bay.
This just started about 3 days ago, and I haven't been able to locate the exact area as it is so short. I plan on taking for a spin with windows down when gets a bit warmer out to see if it does it at all when cruising or slowing to idle.
Old 29 Dec 2009, 06:38 am
Default Re: Whistle Sound when warm starting
Intake leak? Check all hoses. Does it idle okay? If idle is rough, could be intake gasket.
Old 29 Dec 2009, 01:33 pm
dsmturbo's Avatar
Yes, idle is rough at times. I have changed plugs/wires/IAT and a few other sensors.
I suspect I may have a leak somewhere, I hope not intake gasket but my luck it probably is.
I was going to get PCM reprogrammed for the idle/surge problems according to the TSB. I suppose I can spray water or ? to check for leaks?
Old 29 Dec 2009, 02:02 pm
Water is NOT good, use starting fluid or WD-40 to spray around the intake manifold.
Old 29 Dec 2009, 09:00 pm
dsmturbo's Avatar
Originally Posted by Hooligan View Post
Water is NOT good, use starting fluid or WE-40 to spray around the intake manifold.
Okay will do, thanks
Okay, I sprayed WD40 around intake when it was idling and didn't notice anything like a change in idle etc.
Where else should I spray?
Old 11 Jan 2010, 01:20 pm
was it still doing the whistle when you sprayed it? I have seen this a few times. usually the lower intake gasket at cylinder #4.
Old 16 Apr 2010, 08:06 pm
dsmturbo's Avatar
Sorry been away a while. I did get PCm reprogrammed. Didn't drive the car for a few months. I haven't heard the Whsitling sound the past 2 days, but I still have rough idle, some surging and terrible Pinging with Chevron Premium
Old 18 Apr 2010, 06:10 pm
dsmturbo's Avatar
Ya, now I am getting P0304 error again, shows up 2X as a 01 and a 02 on my reader. This car is driving me nuts LOL
Old 19 Apr 2010, 05:20 pm
it's the lower intake gasket. Mine did the same thing, made a whistle noise. The gasket was blown out some on cylinder 4. I changed both the upper and lower gaskets for cheap (from the dealer they're cheap). I always got that code also.
2003 PT Cruiser GT- 15psi, 3" TTAB pipe, K&N drop-in, 3" downpipe, 3" downpipe back exhaust, tokico blues, boost gauge....breaking loose at 50mph
Old 19 Apr 2010, 06:09 pm
dsmturbo's Avatar
Much appreciated TD04, I don't know if I will just replace gaskets or replace complete manifold with plastic. I know it is pricey here, but may be worth it.
If I decide to go plastic manifold route, what other parts would I require, as far as gaskets etc, as I would need to remove TB /EGR /Injectors etc, correct?
Going to go look for a how to on replacing manifold/gaskets
engine whistle 4SPEED Tech & Performance Forum 1 17 Jul 2007 09:22 pm
power steering whistle ptTurbo528 Tech & Performance Forum 5 25 May 2006 05:33 pm
Warm A/C TaylorMade General PT Cruiser Discussions 5 12 Jul 2004 10:25 am
High pitched whistle at WOT rice_killing_GT Turbo Performance 9 28 Nov 2003 08:39 pm
The Whistle... PeTe Turbo Performance 9 10 May 2003 12:25 pm
