Tried searching: Lights flicker at idle
Old 07 Jan 2010, 10:34 pm
Default Tried searching: Lights flicker at idle
Couldn't find any results, saw some for flickering on braking, etc.
Our 03 GT has developed a flickering when car is at idle. When car is off, all lights come on fine, full power (not dim). We have replaced the battery just about a year ago, so I don't believe it's that. When at idle, all lights and headlights flicker. But when you apply gas, lights do not flicker at all.
Sounds like an alternator to me but was hoping to get some more info before pulling the trigger on anything.
Old 08 Jan 2010, 10:54 am
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Default Re: Tried searching: Lights flicker at idle
check your grounds. sounds like a chassis ground is loose or broken. most common one is the one on the passenger side of the hood.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 12 Jan 2010, 12:07 am
Thanks for noting the grounds. I got a DMM just to check everything as you mentioned and noticed the negative terminal on the battery was pretty dirty. Cleaned it up and it appears the problem is solved, hopefully it's something as simple as that.
Cure for dimming/flicker lights igormina General Turbo Discussions 44 22 Nov 2009 07:39 pm
Searching for Part steelheep General PT Cruiser Discussions 3 07 Dec 2008 10:10 pm
Lights Flicker obwan General PT Cruiser Discussions 10 15 Feb 2004 04:00 pm
