TURBO PROMBLEMS DONT KNOW WHAT TO DO
Old 10 Jan 2010, 11:26 pm
Default TURBO PROMBLEMS DONT KNOW WHAT TO DO
The other day i was driving my car and it was fine. Then i was pulling out in front of someone so i had to speed it up . then once the turbo started to spull it stoped and the car started to make a putt putt sound and bog down. i have a 2005 gt pt cruiser does anyone know what i can check before i can see if the turbo is blown? or tell me were the diverter vaulve is so i can check that.
Old 11 Jan 2010, 02:17 am
Default Re: TURBO PROMBLEMS DONT KNOW WHAT TO DO
Check for boost leaks. Check the intercooler hoses and all the vacuum lines. You should use T-bolt clamps on the intercooler hoses because the hoses have been known to leak or even come off with crappy factory clamps. All of the vacuum lines should be zip tied to prevent leaks and from popping off.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 30 Jan 2010, 08:19 pm
PURPLE_GT's Avatar
How many miles do you have on your car? We went on vacation in September and during the drive home my 2004 GT misfired and bogged down when I would speed up to pass one of the many slowpokes on the highway. Then when I got back home and drove the car, it actually backfired when I accelerated from a stoplight. I had almost 60K on the speedo, so I changed both plugs and wires. That fixed it, no more misfiring, bogging down, or backfiring. I did use OEM plugs and wires. I had also changed plugs at 30K as recommended by the manufacturer, it had a very slight misfire back then too, but only at an idle.
Old 30 Jan 2010, 09:15 pm
Two posts of good advice - and let me add - I hope you have synthetic oil in that turbo!
Old 01 Feb 2010, 12:53 pm
Have you checked for codes?
This why you DONT Cut! ! ! ! 02PT Wheels, Tires, Suspension 12 19 Sep 2009 10:37 am
2003 Pt Cruiser Turbo - AC DONT WORKIE ptshmoozer General PT Cruiser Discussions 4 15 Apr 2008 11:42 am
dont need a hemi steve smith General Turbo Discussions 4 19 Sep 2004 10:19 pm
20's dont fit on front... Randall Wheels, Tires, Suspension 9 28 Dec 2003 02:44 pm
