Camshaft pos.sensor replaced ....and???
Old 11 Jan 2010, 10:53 am
Send a message via AIM to mtnbktrek
Default Camshaft pos.sensor replaced ....and???
Ive got an03 gt w65 k miles it threw a cam pos sen code and went into limp mode so I replaced the sensor then the car started and a mile down the rd the code andimp mode came on. Is there 2 pcs with the cam or one? I only got the cover with the o ring . Is it supposed to have the part that bolts to the cam?
Old 11 Jan 2010, 09:10 pm
Default Re: Camshaft pos.sensor replaced ....and???
There have been bad replacement sensors. Did you get it from dealer? They seem better...
Also check the wires/connectors.
Old 21 Jan 2010, 12:34 pm
Hello to all. I am new to this site but am having major issues with my 2005 pt cruiser's camshaft position sensor. Let me begin. Last january I was driving down the road and the check engine light came on and car got all jerky on me. Took it to Adv. Auto parts. They did Diagnostic on it and said camshaft position sensor was bad. Took it to shop and had it replaced(under warranty). 7 months later same thing happened, camshaft position sensor bad again. Took it to repair shop and they said it could be the computer. They replaced sensor and reflashed computer(partially under warranty). Now its 6 months later and the same thing has happened again. Now I have no warranty and shop wants to charge me to replace sensor plus 100.00 to do diagnostic fee for something they have already replaced twice. I am going to purchase sensor and replace myself, but why would this thing keep faulting on me? Is there a way to check wiring? Also shop said some of my sensors were not getting proper voltage. Huh? Please any advise would be much appreciated. Thanks, Scott
Old 21 Jan 2010, 01:50 pm
If you look at the posting after yours you will see that QSD mentioned you can get a bad sensor. When it was replaced under warranty was this at a dealer, (not clear on this), anyway there should be a year warranty on this part. Good Luck!!!
Old 21 Jan 2010, 02:43 pm
Sensor was not replaced at dealer. Done at carx. Only had 12000 mile/12mo. Warranty. Since I use car for work I am 1200 miles over warranty. I just don't see why sensor poops out 3 times in one year.
Old 21 Jan 2010, 03:17 pm
mtnbktrek,
This is for you:
Chrysler PT Cruiser cam sensor replacement: standard and turbo
sdmguinness,
As QSD noted, we've had numerous owners come back to the forum after buying aftermarket parts (especially sensors) where the part didn't work right. When they went with a Chrysler/Mopar part (more expensive) the problem was fixed.
Old 21 Jan 2010, 07:56 pm
I don't think that replacements were factory parts. I called dealer and will pick up another sensor on Sat. Thank you for the link of how to change sensor. I am going to tackle it this weekend. Wires seemed ok. The plastic housing covering wires seemed brittle and missing in places, but wires seemed to look fine. Thanks guys. Scott
camshaft position sensor (CMP) hobbyman Tech & Performance Forum 62 01 Aug 2015 12:43 pm
Camshaft sensor (again!) ABrown Tech & Performance Forum 21 29 Mar 2012 03:31 pm
Camshaft Position Sensor ejschultz Tech & Performance Forum 6 22 Sep 2010 09:58 pm
Replaced Camshaft sensor and car still wont start john1561 Tech & Performance Forum 3 29 Jun 2008 06:49 pm
Camshaft Sensor ABrown General PT Cruiser Discussions 2 18 Jun 2008 07:36 am
