2.4 srt 4 into 02 PT??
Old 17 Jan 2010, 07:15 pm
Default 2.4 srt 4 into 02 PT??
im new to the PT cruiser world and have the opportunity to buy a 01 any how i have a complete drive train out of a srt-4 dodge neon turbo stage 1 laing in my shop . is it possible to do the swap easily in a 01?? i know the intake and some things are different but im not 100% sure what all needs to be done.
Old 17 Jan 2010, 10:23 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Default Re: 2.4 srt 4 into 02 PT??
no. the 2001 has a separate trans and engine module.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 17 Jan 2010, 10:25 pm
i have the complete srt wiring and ecm and transmission i have everything other then a body including keys, fobs, ignition, skim everything.
Old 17 Jan 2010, 10:42 pm
Is the '01 a manual? Because all SRT-4s are manual, so you'd have to make for a clutch pedal if the PT is an auto..
Anything is possible if you are creative, have patience, and/or money...
Old 17 Jan 2010, 10:45 pm
i have the pedal assembly as well like i said i have everything from a srt-4 wreck and was offered this PT for 1000.00
Old 18 Jan 2010, 01:26 am
It won't be easy, but you'll have fun building it. It'll be a GT cruiser as there will be nothing srt about it. The GT and neon srt-4 have the same engine.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 18 Jan 2010, 06:20 pm
ill be using the t850 tranny with it. i cant see it being to difficult to do i have one many custom motor swaps in the past so this motor is ment for a pt any how should make it allot easier. i just wasnt sure if there was anything different in the earlier pts compared to the late ones.
Old 19 Jan 2010, 12:15 am
The srt-4 uses a different intake manifold, intercooler plumbing, intercooler, the throttlebody is reversed, and different pcm programming. All can easily be overcome with GT/turbo lite parts. I heard the t850 was 1 1/2" too long to fit in the PT. I don't know first hand so I don't know for sure. Have fun and keep us up to date.
Old 19 Jan 2010, 08:07 am
ChefTank's Avatar
T850 is euro garbage that was designed for diesel applications and used in the srt4. Its not made for power shifts or clutch drops. What starts out as spider gears (if driven rough) will end up as a pile of shavings. Get the getrag 5 speed. The can be had for $600 and are reffered to as "rock crusher".
Josh
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 19 Jan 2010, 10:10 am
ROCKETMAN8060's Avatar
Cool Re: 2.4 srt 4 into 02 PT??
[QUOTE=srtcruiser;289075]im new to the PT cruiser world and have the opportunity to buy a 01 any how i have a complete drive train out of a srt-4 dodge neon turbo stage 1 laing in my shop . is it possible to do the swap easily in a 01?? i know the intake and some things are different but im not 100% sure what all needs to be done.[/QUOTE
I found this info for you about a guy that did the same project you want to build. I hope it helps.
Eric Cordero's Page - PT Cruiser Network
ROCKETMAN8060
