Turbo replacement
Old 18 Jan 2010, 03:34 pm
Default Turbo replacement
Hello,
My turbo went out on my 03 gt cruiser. I have it taken apart to the turbo and have removed all the lines, hoses, etc. I am however having difficulty with removing the turbo from the exhaust manifold. It seems like the heat has mated them quite tightly. is there anything that I am missing in removing the turbo. Do I just need to apply more pressure to break it free ?
Old 28 Jan 2010, 11:15 am
Send a message via Yahoo to partyd
Default Re: Turbo replacement
Try penetrating lubricant a few minutes before, if that don't work Heat the bolts with a propane torch Apply heat directly to the bolt and nut. Once the bolt is hot, try again with with a lon wrench in the worse case if it gets damage , you need new screws
good luck
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 11 Feb 2010, 12:57 pm
I got the turbo off, new one back on. Now I don't remember where the vacuum lines go. The diagram on the radiator support is not helping...Anyone ? Please !
Old 22 Feb 2010, 06:28 pm
did you remove them from the solenoids?
I'm guessing because I'm at work but...
Orangish one goes to the WGA
tanish one goes to the SVA
thicker hard black plastic with the fitting goes to the top of TB
and one goes to the turbo.
Like i said it's a guess by a bad memory but the hard line angles may help determine where they go.
when reinstalling the turbo, YOU DID make sure you had the shim & alignment pin in right? If not it will a huge boost leak.
GL
KB
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
03 Turbo Radiator Replacement hanks424 Tech & Performance Forum 15 29 Sep 2011 08:22 am
Turbo Replacement Question PTCruzzn General Turbo Discussions 7 06 Jul 2009 07:14 pm
Will receive my "replacement turbo car" soon! Gary04GT General Turbo Discussions 4 06 Sep 2003 02:39 am
air intake replacement o3 turbo amx1397 Vendors & Buyers Forum 2 02 Apr 2003 01:50 pm
air intake replacement 03 turbo amx1397 Vendors & Buyers Forum 1 31 Mar 2003 04:41 pm
