obd-II codes
  #11 (permalink)
Old 03 Jun 2009, 05:49 pm
Default Re: obd-II codes
The downstream 02 sensor is located on the left side of the CAT.
  #12 (permalink)
Old 06 Jul 2009, 02:35 pm
Perrior's Avatar
Re the O2 sensor location can you elaborate a little. Is the Downstream side the drivers side or Passenger side..
I get confused sometimes I can't remember if the left side is looking at the front of the car or setting in the drivers seat looking out.
I just developed this same problem in my 2004 turbo..My car gets so bad it shuts down and won't start.. I have to wait till its cold then it will start but then after its hot it shuts down again..The obdII give both a 32 and a 38 so I don't think replacing one O2 sensor will fix the problem.
I'm on my way to the the library to see if I can get some info on the heater control circuit..
Thanks
Bob
  #13 (permalink)
Old 06 Jul 2009, 05:20 pm
When someone says left side, it refers to the drivers side.
Here's something from PT Do-It-Yourself.net:
I have a 2004 Dream Cruiser GT (HO) with 168k miles. About 300 miles ago, I had to replace both my Cat and O2 sensors, due to multiple fault codes. All was well after the replacement until I tripped codes P0032/P0038 yesterday. I checked the wiring on the after Cat sensor and everything looks good. I cleared the code, restarted the car and immediately tripped the CE light again. The car runs fine, but I am concerned about driving in this condition. Appreciate your input and time. – Larry, from Iowa.
P0032 – O2 Sensor 1/1 Heater Circuit High
Possible causes include:
O2 Sensor Heater Operation
O2 Heater Element
O2 Heater Ground Circuit Open
O2 Sensor
O2 Heater Control Shorted To Voltage
O2 Heater Control Circuit Open
PCM
P0038- O2 Sensor 1/2 Heater Circuit High
O2 Heater Element
O2 Sensor
PCM
The upstream oxygen sensor (1/1) threads into the outlet flange of the exhaust manifold. The downstream heated oxygen (1/2) sensor is mounted after the catalytic converter.
  #14 (permalink)
Old 06 Jul 2009, 06:54 pm
Perrior's Avatar
I have saved some instructions for testing the heater control circuit on the O2 sensors.. I haven't had a chance to check my car out yet but I will..
I can't upload the files as they are too big so if you want them email me and I'll send them to you.
Bob
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
2003 Error codes Reed Tech & Performance Forum 4 15 Aug 2007 08:12 am
Check Problem Codes Yourself! turbomangt General PT Cruiser Discussions 13 23 Feb 2006 06:27 am
