obd-II codes
Old 13 Oct 2003, 11:26 pm
Default obd-II codes
OBD II Fault Codes Reference Guide
The Diagnostic Trouble Code numbering follows a standardized structure. All Diagnostic Trouble Codes have a letter followed by a 4-digit number (e.g. P1234). The first letter indicates the type of code:
P = Powertrain
C = Chassis
B = Body
U = Network Communication
The remaining 4-digit number specifies the problem within that system.
P00XX Fuel and Air Metering and Auxiliary Emission Controls
P0010 “A” Camshaft Position Actuator Circuit (Bank 1)
P0011 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 “A” Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 “B” Camshaft Position - Actuator Circuit (Bank 1)
P0014 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 “B” Camshaft Position -Timing Over-Retarded (Bank 1)
P0020 “A” Camshaft Position Actuator Circuit (Bank 2)
P0021 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 “A” Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 “B” Camshaft Position - Actuator Circuit (Bank 2)
P0024 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 “B” Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
BACK
P01XX Fuel and Air Metering
P0100 Mass or Volume Air Flow Circuit
P0101 Mass or Volume Air Flow Circuit Range/Performanc
Old 24 Oct 2003, 07:43 pm
thanks!! thats some list hope i never need it!!
Old 26 Oct 2003, 04:02 pm
please note there are a few missing, feel free to addthem to this thread.
Old 05 Nov 2003, 10:43 pm
My '03 Dreamer constantly has the check engine light come on while cruising...
but NO fault codes! Wha hoppening??!!
Craig
\'03 Tangerine Dream Cruiser - Chrome Beltline kit, AMP Billet fuel door, chrome grill kit, H&R Sportline lowering springs, PT-Tuning straight thru exhaust, Hallman boost controller & stage one with Mopar blow off valve kit - 240 hp+
Old 06 Nov 2003, 10:12 am
Damn dude.......I hope you didn't sit there and actually type all of that......
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 06 Nov 2003, 02:34 pm
Hey there Bud, That's the MOST info I've found on ANY site/forum. I will print it asap......Thanx again...Stew
\'04 GT w/auto stick, tinted, remote start, boost guage, BTG exh.,seatcovers, armrests,sunroof,.........
Old 03 Jun 2009, 04:39 pm
Default Re: obd-II codes
great post punch, question, i have a 2003 gt turbo, the engine light has been on for awile, no problems with performance or anything else until i went to get a smog cert. couldent get it cause code poo38 ho2s bank 1 sen 2 heater circuit high. where is this heater circuit ? is it somthing i can replace myself with average skills ?
Old 03 Jun 2009, 05:23 pm
Pappabear, that's a 6 year old post your replying to.
According to PT Do-It-Yourself.net ...
P0038- O2 Sensor 1/2 Heater Circuit High
Possible causes include:
O2 Sensor Heater Operation
O2 Heater Element
O2 Heater Ground Circuit Open
O2 Sensor
O2 Heater Control Shorted To Voltage
O2 Heater Control Circuit Open
PCM
Which means there's a problem with the Downstream 02 sensor and a scanner tool is needed to further diagnose the problem.
Or, you could just replace that 02 sensor and hope that cures it.
Old 03 Jun 2009, 05:32 pm
a little discombooberated right now my baby cant get a smog cert. sorry
Old 03 Jun 2009, 05:33 pm
where is the o2 sensor?
Check engine light, ever hear of these codes? MINIHEMI46 Turbo Performance 15 09 Mar 2010 08:58 pm
2003 Error codes Reed Tech & Performance Forum 4 15 Aug 2007 08:12 am
Check Problem Codes Yourself! turbomangt General PT Cruiser Discussions 13 23 Feb 2006 06:27 am
