REplacing corrigated intake hose
Old 09 Feb 2010, 11:03 pm
Default REplacing corrigated intake hose
AS a Newbie, I just made the airbox mods, dropped in the K&N and returned the "hot air intake kit" to them, based on the advice I got here. Now is there any inexpensive way to get rid of that corrugated piece of hose?
Old 09 Feb 2010, 11:23 pm
Default Re: REplacing corrigated intake hose
Are you talking about the turbo to airbox hose?
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 10 Feb 2010, 01:12 pm
Default Re: Replacing corrigated intake hose
Yes, where it goes into the turbo.I was pleasantly surprised by the improvement in throttle response just from the airbox mod, although the noise level was quite a bit higher.That corrugated /concertina bend must do a lot to create turbulence i would think
Old 10 Feb 2010, 02:18 pm
That hose has a baffle in it that narrows flow down to 1 1/2." You can make your own hose. Some 3" hose, 3" pipe and an elbow that is 3" that goes down to 2 1/2" that attaches to the turbo. You'll also need a nipple on the pipe for the vacuum hose. Pretty easy to make.
Old 10 Feb 2010, 03:43 pm
Will radiator elbow take the heat OK? Why does the stock hose have the baffle and restriction-just curious.
Thanks
Stu
Old 10 Feb 2010, 05:35 pm
Thanks
Stu
Baffle is to quiet car down. They figured older folks wouldn't want the noise. That's why there are three baffles in the airbox system. For the elbow you want something like this. Starts at 3" and transitions down to 2 1/2". Silicone Hose - Reducing 90 Degree Bends
Old 10 Feb 2010, 08:32 pm
ChefTank's Avatar
there is a amx ttab pipe on ptcrew for $85 to your door
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
Old 10 Feb 2010, 10:03 pm
If you look around and compare prices for the transition elbow coupler you can make this cheaper yourself. I did.
Old 10 Feb 2010, 10:54 pm
Which forum/thread did you see that, because I couldn't find it in the amx threads?
THanks
Stu
Old 11 Feb 2010, 12:02 pm
[QUOTE=Mean Green;291424]That hose has a baffle in it that narrows flow down to 1 1/2."
Showing my ignorance here, but can you explain why narrowing hose down to 1.5" reduces noise? Based on motorcycle tuning I have done, I'm thinking maybe this increases low end torque, like fitting a smaller bore carb to a bike increases acceln at the low-mid end at the expense of HP and max speed? Seems I have a lot to learn. I have been doing searches here and on PT crew to learn as much as possible since this is my first turbo motor. Many thanks to everyone out there for answeing all these dumb questions
Stu
03 GT Intake hose and lower box with AirRaid Quick Intake Pt_SRT Classifieds: For Sale/Trade 2 16 Feb 2010 06:36 am
Airraid Intake box + filter + one hose clamp DJmart Classifieds: For Sale/Trade 1 01 Dec 2008 08:14 pm
silicone air intake hose ???? bigpoppacat Tech & Performance Forum 1 17 Oct 2005 10:08 am
BTG Turbo intake--Blue hose nbr10 General Turbo Discussions 0 08 Aug 2003 11:47 pm
Hose head BoyJusCruisin Tech & Performance Forum 2 30 May 2002 12:32 pm
