temp gauge fluctuation & overtemp light & CEL
Old 20 Feb 2010, 08:06 pm
Default temp gauge fluctuation & overtemp light & CEL
2003 pt gt turbo, 56k mi. background: CEL came on, p0304 codes for misfire on #4 cylinder and p0116 coolant temp does not make sense. inspection showed an empty coolant overflow tank and dried coolant residue around thermostat housing. spritz from a water bottle indicated leaking lower intake monifold gasket. I replaced that and the gasket around the thermostat & refilled with zerex g-05 hoat coolant (old coolant looked good). drive 12 hiway miles, car was fine. restarted it and immediately pegged the temp gauge, chimed and lit the overtemp light. I let it cool for 3 hours and checked the coolant level (fine). started the car and in 2 minutes it pegged again, now gauge is going from cold to hot, like the ECU is cycling it, chiming, and turning the overtemp light on and off. CEL now illuminates p0117 coolant temp sensor voltage low. Car was hot, I turned the heat on full till I could park it. no air comes out of the bleeder under the thermostat. I stop, remove and test the thermostat, which is only opening 1/16" AND the bleed hole ball is stuck. got a new thermostat (tested the new one, it opens 1/8") then gutted the old thermostat as a better way to test and make sure an air bubble wasn't causing the problem. With this gutted thermostat the heater barely heats the car so I know the engine is cooler and will not be damaged, yet the temp gauge is still dancing around with overtemp lit. on the drive home. I plan on pulling and testing the sensor now, but is this gauge movement due to ECU cycling to exercise the sensor or the sensor itself? Could I be missing another failure point?
tom
Old 20 Feb 2010, 08:24 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Default Re: temp gauge fluctuation & overtemp light & CEL
coolant sensor is bad. replace it. problem solved.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 20 Feb 2010, 09:25 pm
AGREE
Old 21 Feb 2010, 12:40 pm
Tend to agree, since you did do bleeding of air - which could also cause it.
Old 27 Feb 2010, 12:01 am
new sensor solved the problem. BTW it is replaceable without removing all the stuff in the FSM, using just a deep socket and ratchet. Not much room to swing the ratchet though...may need a fine tooth one.
Outside Temp Gauge Jeff V General Turbo Discussions 20 13 Dec 2010 06:00 pm
Fluctuations in temp gauge Ethan1 Tech & Performance Forum 0 21 Jun 2009 11:12 pm
Whacky temp gauge - SES light bobdole369 General Turbo Discussions 1 13 Feb 2009 10:04 am
Factory Temp Gauge ZZCruzr General Turbo Discussions 48 16 May 2004 10:03 am
AutoMeter Water Temp Gauge jramosGT Classifieds: For Sale/Trade 6 30 Jan 2003 07:11 pm
