I need some info please. Can someone tell me where the bracket that holds the rear of the intake manifold up connects to? I'm guessing the head.The dealer did not replace mine and I think it's to much weight to have only the 5 front bolts hold it up. I'm going to call them tomorrow to get a replacement. The bracket would be behind the coil. The reason I'm, asking is if it's EZ to replace I will. If not they will. LORD only knows how long they will take to do that[B)] Thanks
No way!
It's a heavy metal bracket that has 2 bolts holding most of the weight of the back of the manifold. Why did they remove it? damn straight THEY better replace it. Love getting your car back with more probs than when u gave it to them. [xx(]
![]() 2003 GT Inferno Red,5-spd,Eibach Springs,Koni Sport Adjustables, Eibach front and rear Sway Bars, Mopar Stage 1,Mopar BOV,Custom 2.5\" Dual Tip Exhaust (Magnaflow),Hurst Short Throw Shifter, Pioneer DEH6500 Headunit, RF Punch 300 and 301 Amps,RF 12\" Sub and MB Quart Reference and Premium Speakers,Ronal RT 17x7.5\'s with Michelin Pilot Sport 225/45ZR17s, Koni Adjustible shocks, Keystone single scoop, GT Airraid Intake, Mopar Ground Effects Homepage: http://www.cardomain.com/id/ptgtredman http://blueman.ptenthusiasts.net/index.html |
OurPTGT
As you can see there are four bolts which are required to attach it. So you need: the bolts to attach it and the diode assembly. ![]() [|)] macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
I'm reading the owners manual and I don't see this bracket listed, there is a braket at the front of the engine for the manifold but nothing listed for the rear.
Actually, this is a pic of the non-turbo bracket. The turbo bracket has 3 bolts holding it. Two on the manifold and one to the block. The turbo bracket is triangle shaped. I found it on page 2A-5 in my Chilton manual.
[/quote] Duohhh!!! Well he should get an idea from this anyway. But if so, then he will need 3 bolts, and the diode assy. BTW, I did a screen capture of the image in the service manual, plus my Haynes manual Chpt 4-16 paragraph 18 Turbocharger removal and installation section has the same view, plus my Stage 1 Turbo Upgrade Kit install procedures page 4 of 13, figure 13 has the same view, so you can see why I "assumed" that this view was correct. He He He ![]() macster
Had to take the top 2 bolts off on S1 install, it is there, and NEEDS to be there!
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge. Elbert Hubbard (1856 - 1915) 2003 Electric Blue GT-30,000 Miles on the clock Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners Support Your Right to Arm Bears
You guys ROCK! That's EXACTLY what I'm talking about! Thanks!
See Kevin's 2003 Elec Blue GT here: http://www.cardomain.com/ride/477590/1 |
If they left that off, it tells you a lot about their approach to maintenance.
![]() ![]() \"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\" Benjamin Franklin, Historical Review of Pennsylvania, 1759 www.cybermopar.com TripleJack |
huh, don't know how i missed that, but have since found it.
| Need diag. code info | RIvey | Tech & Performance Forum | 1 | 01 Oct 2005 12:05 pm |
| Looking for contact info | drdave | General PT Cruiser Discussions | 3 | 10 Jan 2005 12:05 pm |
| Chrysler 300/ Dodge Magnum info | TripleJackInGA | Non-PT Discussions | 9 | 30 Mar 2004 08:55 pm |
| Info on the 2004 PTC Platinum Edition | Gary04GT | PT Cruiser News and Rumors | 9 | 28 Aug 2003 10:15 pm |
| Wiring Info Needed | GTPT | General Turbo Discussions | 3 | 15 May 2003 11:01 pm |
