'06 HO runs a bit rough at idle
Old 19 Mar 2010, 02:34 pm
Wink '06 HO runs a bit rough at idle
Our 24k original mile '06 PT GT HO Turbo still runs a bit rough and even surges faintly at idle in gear (automatic) after replacing the plugs and wires with performance stuff.
we were using Sunoco 93 octane fuel, switched to Chevron 93 octane and that helpped quite a bit-(all our fuel here is 10% ethenol) and it ran fine before the switch to 10% ethenol.
I believe I read somewhere that some folks have turned up the idle about 50 rpm to help smooth this out......is this OK to do? and if so how do I do it?
Any other suggestions??? Thanks!
Old 21 Mar 2010, 11:28 am
Wink Re: '06 HO runs a bit rough at idle
May be I should clairify: At 11k miles the engine began to run a bit rough at idle in gear, I had read about this and what to do, so I bought a set of aftermarket oem style replacement wires and new plugs, installed them and all was fine until 22k mile mark, same situation, so I bought the MSD wires, and more new (Autolite) plugs, installed them and all was better but not as good as before-(mind you we are now running gasoline with 10% ethinol so I think this has something to do with it-no way around the gas thats available-execpt on the other end of our town there is a station still selling ethinol-free gas-so I might try it.
So aside from that does anyone know to turn up the idle just a tad on an '06 GT HO Turbo engine? I'd like to try that.....it can't hurt, and I can always go back if I need to. Thanks!
Old 23 Mar 2010, 10:30 am
Default Re: '06 HO runs a bit rough at idle
Do you have Air or defrost on? when compressor kicks it, it alters idle.
I know of no way to alter idle speed.
Old 23 Mar 2010, 10:38 am
Dino's Avatar
Were the autolite plugs the platinum plugs? They have issues with turbo's. I heard Chevron was one of the last to switch over.
Old 23 Mar 2010, 11:20 am
You really can't adjust the idle unless you have a tuner system. I would check your vacuum for small leaks or some other cause. Have you checked for codes?
Rough Idle badkarma76 Tech & Performance Forum 30 21 Jul 2009 07:47 pm
Rough idle 03 GT elmeyer Tech & Performance Forum 2 03 Jul 2009 09:44 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Rough Idle BlueBlurCruiser General PT Cruiser Discussions 15 07 May 2004 09:50 am
Rough idle PTPaul Tech & Performance Forum 1 17 Oct 2001 05:34 pm
