engine swap
Old 19 Mar 2010, 10:37 pm
Default engine swap
i am need of some assistance so I come to you guys first.
now my problem:
I just finished my engine swap of a 2002 pt cruiser to a 2003 pt gt engine. I used the stock harness because computer change from 2002 to 2003. I have an apexi safcII for the fuel adding when I boost. Now the engine is hooked up with trans and mounted. Me and my friends did a test run finally today and it turns over but won't actually run. it just keeps turning over until the batter is dead.
We had to lengthen some of the engine harness because the intake manifold is diff on the gt so therefore made us come up short else were. the reason for it start would be our wiring? one thing we did notice is that the crank position sensor is on the front side of the motor on the gt and on the backside of the motor on the n/a. does that make a difference too?
Me and my friends are stumped!!!!
Old 17 Jun 2010, 09:53 pm
Send a message via MSN to sploosh
Default Re: engine swap
hey there i just did the same to my pt i got a 01 and i just changed to a 2003 gt moter if u dont put the gt harnis in the moter wont read it thats your fireing problem also the computer on the firewall to your stock moter only has 2 plugs the gt moters computer has 4 plugs
Old 17 Jun 2010, 10:01 pm
hey there i just did the same to my pt i got a 01 and i just changed to a 2003 gt moter if u dont put the gt harnis in the moter wont read it thats your fireing problem that and the computer for your stock moter on the firewall has only 2 plugs the gt moters computer has 4 plugs
engine oil pan swap cruizinla Tech & Performance Forum 2 13 Oct 2009 07:32 am
engine swap nimblemotors Tech & Performance Forum 10 01 Aug 2009 02:09 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
