Spark plug replacement
Old 20 Mar 2010, 07:43 pm
Default Spark plug replacement
Guys, I am new ti this forum and I need some help. I have a 2008 pt turbo and I am not sure as how to replace the spark plugs. The manifold is in the way and I am not sure what to disconnect.
I am looking for a step by step guide as how to chnage out the plugs. Pics would be great
Old 20 Mar 2010, 09:30 pm
Ratdaddy's Avatar
Default Re: Spark plug replacement
start here... Spark plugs again
Old 21 Mar 2010, 07:59 am
War_Eagle's Avatar
That is a good article, about which plug everyone recommending, but doesn't address the removal of the air intake on the second generation GT with the bulky plastic intake not the aluminum intake that did not need removed. Anyone with first hand experience on this procedure please post. Photo's would be great. By the way welcome to the forum.
2005 Silver GT, auto, black leather, HID Headlights, ST Front sway bar, 215 45/17 tires, dark tinted front windows, stock running gear, sickspeed black pearl shift knob.
Old 21 Mar 2010, 03:32 pm
xwing777's Avatar
Most are using this type of flex socket or removing upper intake to do it.
Old 22 Mar 2010, 09:01 am
Guys thanks for the info, is there a way to remove the upper intake from the throttle body. There has to be an easier way to change the plugs out
Old 22 Mar 2010, 03:43 pm
xwing777's Avatar
Ive removed mine mutiple times by only removing the upper to lower bolts, unhooking the cables then laying it to the side without removing throttle body. Also some have lightly trimmed the plastic edge to make extensions fit but i havent seen any in person yet so dont know wxactly how deep they go.
Old 22 Mar 2010, 04:01 pm
Do the bolts have to be torqued down? or just tight as possible? there has be to a simpler way , what about the gaskets do they need to be replaced as well?
Old 23 Mar 2010, 11:28 am
I swapped the composite intake onto my 2003 and I can get all the plugs except one using a swivel. All I had to do was take a die grinder to one very small area not even 1/4 inch worth and am now able to get the last one too without removing the upper.
Yes you do have to retorque the upper to lower if you remove it. There are no gaskets, they are rubber o-ringed.
Old 11 Apr 2010, 10:07 am
I would like to the size/type of screw that is located on the back of the 2008 pt cruiser turbo intake plenum.
There are 2 screws back there and I misplacd one of them when I was changing my spark plugs.
I think that is a size 10, but is anyone has a PN or correct size/length that would help out.
Thank you
Old 11 Apr 2010, 01:46 pm
If you have a inch/pound torque wrench you can use that and torque to 105 in/lbs. Torque in this pattern 5,3,1,2,4.
After I took the head off of one of the bolts and had to buy another, I was talking to a tech at my dealers and he stated, "I never use a torque wrench on them, I just snug them down using a 3/8" drive ratchet wrench". It worked the last time for me. Gaskets can be reused, no problem!!
need spark plug help please edj8 Tech & Performance Forum 42 25 Aug 2010 12:47 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
oe spark plug gap? thundercat2 Tech & Performance Forum 3 20 Jun 2008 10:22 am
Spark Plug GAP duffner General Turbo Discussions 11 16 Mar 2008 12:55 pm
Spark Plug Gap sakigt Turbo Performance 8 09 May 2003 03:47 pm
