damn codes...
Old 21 Mar 2010, 07:33 pm
superpug666's Avatar
Default damn codes...
hi guys...im getting (not in that order) code 137 138 139 172....the light can sometime go away for a week or 10 minutes lol doesnt seem to b related to the gaz im using.....im thinking it might be wire related .....by experience, do yall think i should by another 02 sensor? (thinking rear one)
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
Old 21 Mar 2010, 08:18 pm
Default Re: damn codes...
What's the story? Have you replaced the front one already? If so, can't hurt to replace the rear. Without even a code I replaced both as preventative maintenance at around 90K.
Old 21 Mar 2010, 08:30 pm
im at 107 000km (roughly 67 000 miles), i didnt change the front, i was told to do the rear because the first code that came out was 138....
Old 21 Mar 2010, 08:49 pm
Your probably right.
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
Old 21 Mar 2010, 09:34 pm
1. feels always good when crewzin says your probably right lol......
2. when my car was lifted i looked a t it quickly and looks not to had to change... what do you think? i saw some website seling rear for pt and had 1 wire others was 3 or 4 wires..wich one is true? thaks!
Old 21 Mar 2010, 10:39 pm
It's been awhile since mine were changed. The front sensor carries 4 wires and I'm pretty sure the downstream (by the converter) has 4 wires also. Some word of advise. According to what I've found in search, don't buy a universal 02 sensor. Replace your with either a MOPAR sensor or a Denso direct fit sensor.
Old 22 Mar 2010, 08:14 am
quality issue?
Old 22 Mar 2010, 08:24 am
It's just that we've heard from owners on this forum that replacing sensors with aftermarket parts doesn't always fix the problem and when changed to Chrysler parts (although a bit more expensive) does fix it.
Hey, take a look at it and if it's really easy to unplug and unscrew the sensor, just pick up an AutoZone or Pep Boys (whoever) sensor and throw it on. If it works, you've saved yourself a couple of bucks.
Old 22 Mar 2010, 08:28 am
thanks! see if autoparts store around here carry sensors like that and see....in quebec we dont have autozone or pep boys....since better weather is here (kinda lol) ill be able to ramp the car and take a look again....thnaks!!
Old 30 May 2010, 08:06 pm
just a quick update, i changed the o2 sensor (stupidly easy lol) codes are gone, unless i leave the key in start the check engine will apear but if i checks for codes it says none lol but better gas millage i love that!
Damn fog lights.. ucantcme General PT Cruiser Discussions 29 02 Aug 2009 09:35 pm
DAMN THEIVES PT Chix General PT Cruiser Discussions 5 11 Mar 2006 08:44 am
Damn I miss my PT... Hardsuit General PT Cruiser Discussions 2 29 Mar 2004 10:46 am
Damn CEL rice_killing_GT General Turbo Discussions 4 01 Feb 2004 06:32 pm
damn people. Punch General Turbo Discussions 4 25 Aug 2003 01:54 pm
