2 Questions
Old 23 Mar 2010, 07:39 pm
Jcamden's Avatar
Default 2 Questions
I have a turbo lite setup and am running on regular. Would it be safe to use a higher octane or should I just buy the S1 pcm and run the higher octane anyway.
Other question is, I recently installed a boose/vac gauge and am noticing that the vac starts out at around 20 "hg" i think is the term. Then while im driving it will move up to around the 27 to 30 range and hold. Normal?
Thanks in advance..
04 - Platinum PT 2.4l turbo
Old 24 Mar 2010, 08:58 am
Default Re: 2 Questions
1) You can put in premium, but it won't do anything except empty your wallet faster.
If you do go Stage 1, you will need premium.
2) Hg is the chemical symbol for mercury. Inches of mercury is used to measure atmospheric pressure - roughly, 30 inches of mercury is normal at sea level - more is "high pressure", less, "low pressure".
I don't have a boost gauge, so I don't know more.
Old 24 Mar 2010, 09:54 pm
ChefTank's Avatar
Thanks in advance..
when letting off the clutch at any rpm i see 25-30 "hg"... it means you have NO boost leak. at idle it should sit at 18-20 "hg". premium is your choice, at $3.00 per tank diff i would error on the side of safety. IMHO.
Josh
what do i know, i'm just a cook
This is my turbo History:
Stock turbo (1 year)
Big Wheel Stocker (3 Months)
50trim (2 Weeks)
Stage 3 (3 months)
Big Wheel Stage 3 (6 months) my Fav
Holset HX35 (6 months) 700whp turbo
Stock turbo its a daily driver now
I've done this once or twice before...
New PT, some questions YouPutz General PT Cruiser Discussions 6 07 Dec 2009 01:15 pm
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
2 Questions jmack General PT Cruiser Discussions 3 29 Sep 2004 03:51 pm
hello all new pt questions bobs turbo pt General PT Cruiser Discussions 8 25 Aug 2004 06:35 pm
Two Questions PTGT Redman Turbo Performance 7 26 Aug 2003 08:01 pm
