new pt gt owner with questions
Old 25 Mar 2010, 06:12 am
Default new pt gt owner with questions
My dad just gave me his 2003 pt cruiser gt with 89,000 miles. I drove this car when he got it new and it used to have alot more power. No cel on but feels like it bogs out under hard accelleration. Any info on where to start looking would be great. Thanks
Old 25 Mar 2010, 06:44 am
Default Re: new pt gt owner with questions
Ask your dad when the last time the plugs and wires were changed, then go from there. If it's been awhile, you should notice a big difference.
Word of warning. You coming up to the 100K mileage mark. There's a major mechanical job that's recommended at that mile stone. It's the timing belt and water pump change and along with that, the belt tensioner and both drive belts should also be changed. Done by a Chrysler dealer or a private mechanic, it's still around $1000 with parts and labor.
Old 25 Mar 2010, 08:27 am
It's dad's like yours that give the rest of us a bad name...
Crewzin is right - plugs & wires don't last - particularly the wires. Gap plugs at 0.035.
Also change the air filter - for about $45 you can get a K&N, which breathes better.
Also check the tire pressure - the correct amount is posted on th driver's door - low pressure = more rolling resistance - trust me, you can feel it.
Old 25 Mar 2010, 04:52 pm
Thanks for the responses. I have all repair receipts since new and the plugs were changed at 62k but no mention of wires and i havent checked the air filter yet. Im an auto mechanic but have never owned a turbo before and also he had the timing belt, pulleys water pump and hoses changed at 70k. It did have the pcm,cam sensor,knock sensor changed at various times. I just got it yesterday and couldnt even get it on a lift at work yet lol.
Old 25 Mar 2010, 06:05 pm
Check for boost leaks. Zip tie all vaccuum hoses and use t-bolt clamps on the intercooler hoses. The factory worm drive clamps suck and will leak.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 31 Mar 2010, 08:44 pm
Sorry for jumping in on this post, but how many clamps do I need for my '03 GT? What size should I get and where would you recommend going for them? I'm planning a big road trip this summer and would like to make sure everything is sealed up before leaving. Thanks!
Musicman
Old 06 Apr 2010, 10:41 am
nevinsrt's Avatar
the T-bolts you would need are 1-2.25 and 4-2.5 if your on the stock piping, if you have hard pipe kit like the AMEX kit you'll need 1-2.25 and 10-2.5
Nevin.
03 SRT-4 132k mi ported stocker and lots of other stuff
68 Mustang Coupe project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. last dyno 245hp/283tq @ 15psi OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
New PT Owner w/Questions... JD78 General PT Cruiser Discussions 8 25 Dec 2009 12:28 am
New owner with a few questions... zygote General PT Cruiser Discussions 9 15 Aug 2009 12:25 pm
New GT owner with some questions 14GDHPs4ME General Turbo Discussions 8 31 Jul 2009 12:49 pm
New PT Owner Has Questions Ineffable_Jeff Tech & Performance Forum 6 03 Aug 2008 04:15 pm
New GT Owner...A few Questions jbrown1977 General Turbo Discussions 13 18 Mar 2004 05:56 pm
