Auto Stick and The 180 HP Turbo "Lite"
Old 21 Oct 2003, 09:42 pm
Default Auto Stick and The 180 HP Turbo "Lite"
Since we've been told that both the GT and the "turbo lite" share the same transmission, and that the stage 1 pcm will work with the turbo lite, does it make sense that one might be able to add the auto stick module to the "turbo lite" at not to great an expense?
Maybe Tommy can give us some perspective from a parts standpoint.
Old 21 Oct 2003, 11:15 pm
lip lip is offline
The autostick is purely software...probably located in a different module somewhere but I don't see the problem if you source the shifter with sensors and the corresponding module that interfaces with the main pcm...
LIP
2003 Electric Blue GT 5 speed loaded
Old 22 Oct 2003, 12:29 am
I don't get it, why buy the turbo lite only to spend mega bucks turning it into a GT?
Old 22 Oct 2003, 12:35 am
I agree that if it is mega bucks it makes no sense. However, to go from turbo lite to GT Stage 1 preformance ( a 55 to 60 hp gain) will cost about 400 for the stage 1 kit and whatever installation costs (if someone else does it). Let's say it costs 1000 to add the autostick and assume that 300 was spent for labor to add stage 1 kit.
My son's turbo lite cost 19,300 + ttl. With these expenses I would have 21,000 in it. Seems like a fairly good return on an extra $1,700. An even better return if I skip the autostick.
03 GT, Stage 1
Race Pipe and custom 3\" back, Eibach Springs, A Pods with EFT and Boost, MP Underdrive Pulley, 180 thermostat, Taylor Racing Wires, NX wet Nitrous 50 shot for quick spool/hp with msd tac drive and window switch, Mopar BOV, FIPK intake, APC Euro Tail Lite Kit, all badges removed.
Old 26 Oct 2003, 11:56 am
Actually, if your original plan was to replace the sway bars and springs, add shocks, 8"X 17 Wheels and 235mm tires, trick exhaust, your own external trim package. The difference is in how much the original base car cost / how much the throw away parts cost.[8)]
(I now have in my garage a new GT exhaust, and new GT spring set ... what do you do with them?)[:I]
Old 26 Oct 2003, 04:00 pm
sell them to me?
