Help with radiator replace
Old 31 Mar 2010, 10:58 pm
Default Help with radiator replace
Hey guys, I have been getting the little puddle of green and it's time to replace the radiator. I did a search but no result, does anybody have the process to do this? I know cars, I have tools, how hard is this to do? Will it take more than a month?
Thank's much in advance for any help!
Old 01 Apr 2010, 11:19 am
Default Re: Help with radiator replace
Read this thread over and see if it helps. There's 5 pages of information.
Radiator cooling fan
Old 01 Apr 2010, 12:18 pm
Also, don't use the green coolantunless you know it is approved for your PT. The PT has aluminum components. Using the improper coolant will cause a chemical reaction and eventually "eat" (corrode) the aluminum. Coolant for the PT should be HOAT (Hybrid Organic Additive Technology) approved.
Look for Zerex G-05 at your local Napa parts store. Some have reported that it's hard to find in some areas.
I believe that Valvoline makes a G-05 blend as well.
According to this thread below, don't use Dex/Cool.
DexCool Coolant
2005 Limited Ed. 2.4L Turbo
Midnight Blue Pearlcoat with chrome package
Old 10 Feb 2011, 05:02 pm
Ok so I started trying to change my radiator. I got underneath the car and it appears there are high pressure air conditioner lines going to the bottom. is it a big deal if I break these open? If I do can I not just recharge the system once I get the new radiator in? Thanx!!
Old 10 Feb 2011, 05:05 pm
cruserdad1976's Avatar
I think the radiator comes out the top??? mide did anyway
Old 10 Feb 2011, 05:22 pm
That isn't the issue. I need to know if i can disconnect the AC lines without killing myself or my car lol.
Old 10 Feb 2011, 05:55 pm
I think you are seeing the power steering lines going to the cooler that is integrated into the radiator and yes, you can open them up.
Old 10 Feb 2011, 06:23 pm
I agree with Cal Cruzer. They are cooling lines. You will loose coolant but it's not R134 so your not discharging the A/C.
Old 10 Feb 2011, 08:31 pm
chris15's Avatar
Replacing the radiator does require you to purge the AC lines. It's easier if you just purge from the lines that are on top of the upper engine mount instead of trying to remove them from the radiator first. If you have an automatic transmission, the transmission cooler (separate) also has lines that run to the radiator.
I've removed my radiator two or three times in the past 6 months, and the service manual says it as well.
EDIT: And yes, you can recharge the AC system once everything is back together. MAKE SURE TO CAP/COVER THE LINES THAT ARE EXPOSED. You DON'T want any contaminants to enter the AC lines whatsoever.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 11 Feb 2011, 01:30 pm
I replaced the radiator and fan on my '05 PT Turbo Lite last winter. There was no need to discharge the A/C system. The condenser is a seperate unit bolted to the radiator. Just remove the screws and move the condenser a bit.
Check the sticky link to the rapair manual in the tech forum. Nothing there stating anything about the A/C being discharged.
Al already mentioned, the hoses at the bottom of the radiator are cooling lines from the power steering unit. Make sure you refill the fluid when you complete the work. I tried to plug the end of the lines with wire nuts when I removed them to save as much fluid as possible. IMO, it's not worth the hassle. I still lost a bunch of P/S fluid.
How to replace radiator drain plug? hotdog789 Turbo Performance 2 22 Feb 2010 11:57 pm
How to replace A/C compressure? hermtm2 General PT Cruiser Discussions 5 24 Aug 2008 08:18 am
How to replace the Tail Light benivey2 PT Cruiser Videos 2 18 Aug 2008 10:56 pm
TSB - replace PCM GTSteve General Turbo Discussions 28 23 Jun 2004 06:17 pm
