spark plug wire change on 06 turbo limited
Old 05 Apr 2010, 02:34 pm
Default spark plug wire change on 06 turbo limited
I saw the sticky on plug change for 06 but I have a turbo. How much more difficult is it to change plugs and wires? Also any ideas on what plugs and wires are good and what should the gap be on the turbo engine? Thanks, Jay
Old 05 Apr 2010, 03:06 pm
Default Re: spark plug wire change on 06 turbo limited
Stock plugs are good, gap about .035. On a Turbo I understand all you have to do is remove the plugs, the intake does NOT have to be removed. Any plug wires except stock, NAPA have been used by many on here.
Old 05 Apr 2010, 03:38 pm
True, the intake doesn't have to come off, but the plastic intake is tighter than the aluminum one - you'll need a shorter plug socket with a swivel on the end - and I put another swivel before the wrench and was able to do it.
Old 05 Apr 2010, 06:35 pm
Thank you for the Great info for my car. Glad to know the intake doesn't have to come off. Jay
Old 05 Apr 2010, 06:50 pm
Even if it does, it isn't a big deal. Just use a bungee to hold it up and it is out of the way. The gaskets can be reused as they are "O" rings that sit in a groove. I have changed plugs in all 3 of our NA PT's with no problem. Be sure to use dialectic grease in the boots and anti-seize on the threads. Your have to torque the plugs, (I don't have the specs at hand), but someone will chime in.
Old 05 Apr 2010, 09:08 pm
eflyguy's Avatar
13 ft/lbs according to the spark plug guide
Spark Plug Guide
..a
2001 Limited, stock except for burp-shift mod & K&N drop-in for now..
Replaced: fan assembly, plugs and wires, battery.
Old 11 Apr 2010, 10:11 am
Guys, just my two cents, I just replaced the plugs on my 08 Turbo, in order to do so I had to loosen up the intake plenum to get to the two inner plugs, there is no way that it can be done with out doing so.
Suggestion on Spark plug and wire? oLEFTo Tech & Performance Forum 13 08 Jul 2009 11:53 am
air filter,spark plug & wire brands/opinions bob67firebird428 Tech & Performance Forum 21 14 Jun 2008 04:05 pm
my experience with plug/wire change mino General Turbo Discussions 2 31 Oct 2007 03:10 pm
Plug & Wire Change Screw Up???? BB Turbo Performance 12 24 Feb 2007 12:15 am
2006 non turbo spark plug change samson77 Tech & Performance Forum 9 06 Feb 2007 12:36 am
